clpray16
Colton
1973 Ford Bronco , Ford Focus ST
Installed icon 2.5 adjustable coilovers along with Camburg upper control arms, nitto trail grapplers 315/70R17, and Sasquatch take off wheels. Did the install with my dad (he’s on the forum so hi dad) in our driveway, overall it’s a straight forward install which means it took us 15+ hours.
Started with a non squatch black diamond 2.3L manual, there was nothing wrong with the ride stock it was good on and off road. However the switch from stock to icon was night and day, it rides incredibly smooth and plush while also drastically reducing body roll and pitch. Haven’t been able to take it off roading yet but am sure that my bash plates will appreciate the added ground clearance.
There were some difficulties with the instal, the position of the front reservoirs either pushed the hose along the spring rubbing on 4 of the coils or rubbing the the tire at full lock. After speaking with icon we were told we could losses the nut to spin the hose on the revisor without leaking oil, it leaked oil. Icon then got to work on new set of custom front coil-overs and had them ready in an impressive amount of time so props to them. This is a new vehicle and a brand new suspension kit so not that suprised that there’d be issues.
Overall it rides amazing and looks great, programmed the tire size with forscan two days ago so really don’t have enough data to make any real mpg claims but doesn’t seem to be a change. I’ll post updates when I get some time to take it off road with the new set up. It also got a buff, polish, and ceramic coat while we waited for parts and looks better than factory now.
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) D6562455-EF06-4E65-BB68-42FD7A48795D
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) 3FC6A566-A1B8-462C-B579-CAAED92A3F20
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) 046B4B06-1E5F-4389-A6DC-05F95625DDD1
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) 7827FB80-BAC8-4FD9-AD9B-A19A1D824C73
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) 81C144F6-85F8-49E3-A28D-D5A714FB051F
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) A9DAC5A4-F196-47AA-ABD7-68AB8000405B
Ford Bronco Icon 2.5 adjustable coilover install (Self Squatch) 6344C340-8D03-4DC3-9A21-3617CF6287AB
Alank34
Alan
La Verne CA
Brknco black diamond
do your tie rods come close or touch the lower part of the shocks when the steering wheel cranked ?
clpray16
clpray16
Colton
No there’s a decent amount of clearance
Alank34
Alan
La Verne CA
Check the threads in the ICON page on the forum, lots of people having issues with that. Maybe you can shed some light on what’s different with your
thanks in advance
clpray16
clpray16
Colton
thanks in advance
I’ll go look, it was tight at first but the alignment fixed it, I’m actually gonna look again to make sure we were focused more on the hose rubbing
Big Diamond
Miles
Atlanta, GA
2022 Bronco HOSS 3.0 Wildtrak
Looks good. Nice work!
Gil Carolina
Gil
Charlotte
Love it. Looks good. Are they adjustable to level of some of the factory rake?
clpray16
clpray16
Colton
Yes I did some adjustments to get it almost perfectly level
Triceratops
10 speed Huffy
*looks like Ridge Grapplers (not Trail)
Looks good, I just did the same thing on my 2Dr A51 Badsquatch. I don’t rub tie rods (had them put some extra castor in the alignment) but because of how low their spring cup is, there is no room for any type of tie rod brace. They are sending me a new lower pin to see if that gives enough room for something. Luckily the disconnectable sway bar seems to have a little more room in the rear.
Many are having rub issues in stock configuration but the alignment may be key. Unfortunately not thought through by Icon before launch.
clpray16
clpray16
Colton
Just found out about that issue, did you or anyone else have issues with the resivor hose rubbing?
Triceratops
10 speed Huffy
I need to play a little more I think my fronts are in contact with the spring in one place. I’m not sure how much it matters. I really had to adjust the rears. The installers were a little baffled by it it seems.
