Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
Having a hard time trying to clarify, does this kit imply an additional 3" to the Sasquatch or is it less? Specifically I am looking for maybe 1"-2" more clearance on my SAS Badlands and not interested in a full suspension at this time.
Also, anybody out there with this kit have an assessment of before and after ride quality? I have never had a leveling kit but assume ride quality remains the same, I have only had full suspension on a Wrangler JL.
It will add 3" front, 2" rear to your Bronco.
Cgybronc
Canada
'20 F350 9"-38s/'15 F350 8"-37s/'10 GT500"stock"
I just purchased this kit but didn’t realize the preload spacers aren’t used in the rear for the Sasquatch. Will the preload spacers fit on the rear Sasquatch coil overs if you didn’t want a level stance?
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
Yes I believe they can be installed if you want to.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Hey Dusty, how's it coming along for the Hoss 3.0? 🤔
@Dusty at ICON Yes, any update on HOSS 3.0 setup? It appears the preload spacer gives 1" lift alone? You then have 2" top hat spacers front and rear?
Ramz2012
Tx
2012 F150 Platinum
I had this lift installed on my 2023 Badlands, 4dr, 2.7, non Sas. Ride is great, no noticeable difference. However, mine resulted in 2” lift in the front and 3” lift in the rear. It was “professionally” installed. What went wrong? It doesn’t look bad but I had assumed it would be leveled following the lift.
Chritaka
DFW, Texas
Sounds like maybe they got the preload or top spacers swapped. Also per the instructions and install video, if SAS, the top spacer isn't installed in the rear.
Chritaka
DFW, Texas
@Dusty at ICON Bump - I also asked about this through the Icon site -> Support the other day, but no reply yet. When will a HOSS 3.0 kit be available? How much lift does the preload spacer alone give up front and rear?
Ramz2012
Tx
2012 F150 Platinum
I figured there was only one way to install it. Are the front and rear spacers different? It’s a non SAS so all parts should’ve been used.
Chritaka
DFW, Texas
Check video in post #92
Marcs1016
Marc
IL
2020 F150 Raptor. 2023 Bronco 4dr
Did you find out if it was installed correctly? I have the same Bronco and will be adding this soon.
Ramz2012
Tx
2012 F150 Platinum
No haven’t gone back to the installer yet. I plan to go back for them to re torque everything in a couple weeks. I’ll find out then.
