Installed: Alternative to Oracle light up Bronco letters
j_anderson
Fort Wayne, IN
www.instagram.com
Mine are always on when the car is on. Even when remote started. When it is used with the supplied fuse tie in. I like it like that, so left it as is. Wiring to aux switch, or directly to the parking lights will be more controllable.
I wired mine to an up fitter switch. I've started double-blinking mine at other bronco drivers as my howdy :)
fallguy
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
@fallguy can you explain how you hooked up to the parking lights instead of the AUX fuse spot? I just installed these tonight - https://www.amazon.com/gp/product/B0CDVZ7L38
Ford Bronco Installed: Alternative to Oracle light up Bronco letters IMG_1299 (1)
Their instructions tell ya where to tap into the fuse panel to come on with the key. Instead of connecting to the aux wire you just put the supplied fuse tap adaptor in the fuse box. Youd just have to find out which fuse is parking lights if you want them switch activated.
