Not to mention rain will not remove bird poop, mud, salt, dead bugs, ect. Wipe after a rain with any kind of material is just going to grind it into the paint. Pretty dumb.Have you ever heard of acid rain?
Most of the time, I go to the self-wash because I need to pressure-wash the mud and dirt that is everywhere. Occasionally, that means pressure washing the mats and sometimes even opening the drain plugs and washing out the floors in front.To be honest I just took my Jeep through the drive through. I knew the risks of scratches from the brushes. But whatever. Since I got the soft top on the bronco I use touch-less sometimes but man it sucks. Found chemical bros kit on sale, now I hand wash. I know there are differentiating opinions on hand, two bucket, power wash etc. what’s everyone’s preferred method? My major hiccups are during the wax phase I get some on the plastic parts and I don’t know how to remove it once on.
One time, you should drink something fluorescent, then use a blacklight and see what you think about the handwash skipping part. Unless you're old and flow pressure isn't what it used to be, you'd be surprised.If Im just taking a leak, i have a touchless method that lets me skip the hand washing. Real time saver.
Omg! He’s right! And they look great! What’s your next nonBronco related tip??
Not that I know of, but learning the proper way to tie shoelaces is amazing.
I thought you were going this way with your response....I usually get my hands wet with warm water, lather them with soap, and wash them for about 30 seconds or so, before rinsing them off in the sink. Pat dry for best results.
The real secret is to moisturize afterwards.
Same here. Rinse, foam canon and with electric pressure washer (warm water), bucket of warm water with microfiber mitt, hand wash while foam is on car for lubrication (2 bucket method), rinse, dry microfiber towel, extra fine microfiber towel for glass, once every two months wash put Graphene shampoo in my mitt bucket water, and ever two months apply Graphene boost for finish to keep it slick.I use an electric pressure washer. First I blast away as much dirt and grit as possible with water. Then I use the foam cannon attachment to lather the entire vehicle. Blast everything away a second time with pressure. Lather it up again with foam cannon, then hand wash with a "clean" bucket and a "dirty" bucket. This method really keeps you from grinding dirt and debris into the paint during washing. If I don't have time for a hand wash, just the pressure washer and foam cannon will suffice...I usually will do this after a long weekend of getting dirty in the mountains.
I never run my personal vehicles through a touch car wash. Guess I'm a 35 year old boomer.
You would be so lucky to be a boomer!I use an electric pressure washer. First I blast away as much dirt and grit as possible with water. Then I use the foam cannon attachment to lather the entire vehicle. Blast everything away a second time with pressure. Lather it up again with foam cannon, then hand wash with a "clean" bucket and a "dirty" bucket. This method really keeps you from grinding dirt and debris into the paint during washing. If I don't have time for a hand wash, just the pressure washer and foam cannon will suffice...I usually will do this after a long weekend of getting dirty in the mountains.
For everyone of average to below average stature with Sas and big meaty tires, I use a work platform to get the windshield and roof. Helps a ton.
https://www.homedepot.com/p/Werner-...rm-with-300-lbs-Load-Capacity-AP-25/301578816
