Locking keys in vehicle?
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
Listen to your wife - get a second key fob, you need a back up anyway. In addition, the other options (app, key pad) will work for this.
A lot of aftermarket key fobs are junk and dealers have trouble getting them to program.
I purchased an identical bronco key fob from a sit called car and trucks remotes.
came in a week. Look identical. Had it programmed shortly after I got it.
cost was around $90 for the remote and there usually will be a cost to have the dealer program it (50-150). Mine took approx 20 min for dealer to program. Works perfect.
I have three fobs now. I got an extra so I can leave it at our lake house as a spare in case I lose one while I am up there.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
I did see the other posts about locking things but the focus there seemed to be NOT wanting to lock the keys in the car. Here I WANT TO lock them in but have a way to (a) let the shuttle service drive it, then (b) lock it but still (c) let us unlock it six days later 100 miles away.
I saw a reference to the FordPass app. Hmm I will look into that too.
If the shuttle service will be driving your vehicle be sure to turn on VALET MODE - for safety.
OmahaKevin
Kevin
Omaha
2012 Mustang GT, 2023 OBX
If you have two fobs you do not need to have the dealer program the third. You can do it yourself. Check the manual.
JBlanco
Julio
Charlotte NC
This is the reason I balled out and paid $110 for the keypad!
Related to the OP situation, I also programmed a cheap $18 used key from ebay to the Bronco in case I lose one fob, I still have two to be able to program a third.
1st 75th ranger
jeffrey
nj
We are rafting in Idaho for 6 days and they will shuttle the car (truck? What do we call these Bronco things?). I can’t find my second key fob so am looking for a way to have them lock the keys in but let me later unlock it. Nothing seems foolproof but the best we’ve got is we leave them the FOB while we take the removable KEY. My wife is lobbying for just order a second fob which we need anyhow.
As I said this needs to be foolproof. Where we pick up the car is still pretty remote!
keyless door pad entry works for me
DOUBLED16
Daniel
Canada
2020 Ford Escape Hybrid
Another option is just leave the roof off and climb on in! Ha ha!
I use FordPass myself since I didn't bother to get the keypad (had it on my F-150 and used it exactly once) and just easier but yes that does require cell service as someone mentioned.
Fmuguira
Frank
Idaho
Jeep TJ
In Idaho many, many places the river shuttles leave vehicles WONT have cell service for useage of FordPass….. just so you know.
Rspayde
North Ga
2022 C/O Black Diamond
I would say keypad or take the physical key with you and lock the fob. If you have a soft-top you could always just lock the doors and crawl in through the rear window when you get back.
Other option is to buy waterproof bag and STRAP it to yourself. I emphasize strapping the key to yourself as losing the only key fob would be detrimental for several reasons.
Scott R Nelson
Meridian, ID
Yeah, a whole lot of Idaho has no cell service.
The best solution is to use a keypad. That allows you to lock the doors with the key inside, which you can't do (at least on mine) by just pressing a lock button or something. You can also pull the physical "key" out of the FOB and unlock the door with that. I went to a quality locksmith and had a copy of that made to keep on my key ring, in case the keypad doesn't work someday. I had one time in the rain when it didn't want to unlock the car and I had that key made the next day. Opening it that way results in the alarm going off if you don't start it within a rather short time.
The correct solution here is to get the keypad entry.
0ne
Nate
CO
Flex
What happened to old school hiding the key/fob on the outside of the vehicle somewhere? It’s rural Idaho not downtown somewhere…have them put it up on a skid plate or myriad other little spots underneath.
trickewon
Rick
Lebanon Pa
2017 mustang gt convertible
If u lock ur key fob in vehicle won't it still unlock for any one who touches the door handle sensor?
Bronc’n Bronco
Kevin
Washington State
2023 Bronco
I put a keypad on the back and wrap the keyfob in aluminum foil and lock in the Bronco. The reason I do this is I scuba dive so my phone is in the rig. I put the keypad on the back door (some put in the gas fill cavity. You have to program the pad with FDRS for this system (used to do it like an extra FOB) it took me longer to hook up the laptop and access FDRS. Programming took under 2 minutes.
Ford Bronco Locking keys in vehicle? 3EAEE122-3893-4274-B2AE-6F6D9A1BF9EF
mcinfantry
Lee
Louisiana
Badlands 2 door
Keypad,then put fob in rfid bag in back
Tested everyday it works
Fun fact
Every bag I’ve tried allows you to open the door at the handle but never lets you start the car
it says no key detected
Solfive
NV
2008 JKUR
It looks like you have a soft top. I have a hardtop so forgive me in advance if this isn’t feasible. My soft top wranglers have all had rear or side windows that I could unzip/unvelcro and then reach in to manually unlock or open a door. Is this possible with the bronco soft top? I’ve done this for many years surfing, hiking, cycling with zero problems. I typically hide my keys on top of the roll bar where very few people would ever look.
