MagSafe Charger Using Dash Mounting Point
rblock50
Ryan
Orange County, California
VW, Bronco
There are several, make that a ton, of posts about the built in wireless charger being a complete POS - it heats up the phone making it turn off and doesn’t even add any juice during the charge. I’ve seen others post their mods, but I didn’t see any that I liked (no offense). Here’s what I did.
1. Purchased a MagSafe Charger - $15
While it’s not an Apple, I wanted it to be black and I didn’t see one from them in black.
https://www.amazon.com/Magnetic-Wireless-Charger-Compatible-Charging/dp/B0BBTFWCMB
2. Purchased RAM Mount MagSafe Holder - $13
This is a cradle to holds the MagSafe charger and it attaches to the arm coming from the dash (#3 Below)
https://www.amazon.com/RAM-Mounts-Adapter-MagSafe-RAP-B-202-AP-MAGU/dp/B09J9ZCDDD
3. Purchased Phone Mount - $33
This connects directly to the attachment point on the dash and offers a ton of different angle options to fine tune the placement of your phone. It even has some female threads on it to attach maybe a Go-Pro.
https://www.amazon.com/All-Metal-Adjustment-Smartphones-Non-Destructive-Installation/dp/B0B3MHJ1NX
I then put all of the pieces together and used black electrical tape to hide the wires. This actually frees up the spot where the OEM charger is so that I can put my wallet and keys there. Now i can quickly pop my phone on and off and not have to use those clamps that most mounts have. It’s super convenient and holds my phone like a champ.
Ford Bronco MagSafe Charger Using Dash Mounting Point CB55DBD0-1F3D-44F4-B578-D23282DE0F2A
Ford Bronco MagSafe Charger Using Dash Mounting Point 11F63D92-176A-4687-8A25-252A1A76CDC2
Ford Bronco MagSafe Charger Using Dash Mounting Point D6DFE0DA-DF18-4AC6-A120-E6D8D87435F0
Ford Bronco MagSafe Charger Using Dash Mounting Point 6D2B0753-2EEC-4258-B0B5-7B6099CDAC68
I am not sure yet if I like having the phone stare at me while driving, but so far it’s OK. Who knows, I may just stick the MagSafe charger on the dash and out of sight completely :)
Mlarv
TN
Never mind I found my answer.
StylinEx
Andy
Irvine
Jeep
Either way whether it is the smartphone or the charger it will need to use a cable so I find it best to get a fast charger with a good cable and then just use fast charger to charge directly to smartphone and either use a magnetic MagSafe holder on back or smartphone holder. The wireless charger will create more heat, not as fast and still needs to be plugged in so best to just plug into smartphone via cable to charge. I went with this option. Charger is Superfast. Magnetic holder never fell off. It holds my tablet and charges it as well
https://igosmart-pro.com/products/new-2022-on-up-ford-bronco-smartphone-holder-mount-for-dashboard
https://igosmart-pro.com/products/igsp-smartphone-tablet-computer-supercharger-for-your-car
rblock50
Ryan
VW, Bronco
Agreed, the wireless charging isn’t as fast as the plug-in for obvious reasons. However, with the items I’m using I don’t have the crazy heat like with the OEM “charger” and it actually charges my phone. I love the slap-on, slap-off of the MagSafe mounts. My phone didn’t have the metal inside of it, so I bought a case that it built in, super easy. The OEM is complete garbage, I don’t know how Ford even let that make it through development. So dumb that we have to pay for something that doesn’t even work.
CarGuy
New Jersey
2023 Ford Bronco
Is it all aluminum?
mhtucker78
Matthew
VA
2023 OBX Bronco
JonDW29
Jon
NoVA
'16 F-150
I'm doing something similar with a tackform arm and an Amazon magsafe charger that I've been using in my truck for a couple of years. I run power to the magsafe adapter out of the port on the dash (I have lux). Charges way better than the cubby charger and doesn't turn my phone into a hand warmer.
I have the tackform clamp style holder that I'll swap out if I'm doing any off roading, but for day to day driving I've found this setup to be plenty sturdy.
JonDW29
Jon
NoVA
'16 F-150
For reference sake, here's the arm from tackform:
https://www.tackform.com/products/d...h-ford-bronco-6th-gen-fast-track-dash-bracket
This is the magsafe adapter I'm using as well. Like I said I'm using this in my truck as well. Unavailable but there are a ton of options here.
https://www.amazon.com/gp/product/B08ZN869MV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The only thing I have left to change is to replace the factory mount with the SLAP BPM from Archetype Racing. You'd have to either order one of their 20mm ball mounts or get a longer bolt for the tackform ball mount. Mainly grabbed it just because, but it is nice to have a couple extra mounting points if I do end up needing them.
https://archetyperacing.com/products/ar-slap-bpm
rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
Thanks so much for posting! Parts ordered!
/Rich
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I didn't find the mag chargers to hold firmly enough, especially when going offroad.
I use a Quad Lock on my motorcycle, so I decided to put mounts in all my vehicles for it. Works great.
https://www.quadlockcase.com/
Agreed. I had a magnetic mount strong enough that I couldn’t remove it by hand when I stuck it to my tool chest unless I slid it to the edge of the box. But 3 bumps in on a trail and my phone was in the floorboard.
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
