MIC 2.0 leaking into A pillar trim
spdrcrx
Tom
Toyota 4runner
Picked mine up 9/2022. Leaking from the drivers side pillar. Anyone actually have the leak resolved with the TSB?
Nym1178
Nicole
Maryland
Yes mine is mostly fixed with the TSB but still occasionally get some water along the A pillar if I take in high pressure washers. Doesn’t happen every time.
Clouded
FLORIDA
2013 Land Rover LR2; 2022 Bronco Big Bend
Glad to hear I'm not the only one still having some leaking after the fix. I've taken mine in twice and its gotten better, but the leak is definitely still there.
Nym1178
Nicole
Maryland
It’s been raining consistently for the last several days and normal wet weather and high speed driving after I properly relatched my roof and I’ve been good. Not a drop. I also have the Bestop Sunrider roof over the front row and love it.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there – send a message to us with your VIN and approximate mileage. I’ll look into this for you. Thanks!
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
I have mine at the dealer right now, they will not perform the Fix unless it can be replicated....spoiler alert they cant replicate the leak so the work will not be done.
Ford Motor Company
Dearborn
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
grayshadow
Charles
Humble, Texas
Yep, that’s why we get the “wash out floor boards” and extended warranty.
jh3113
Jake
Phoenix
Subaru Outback
Bronco was out stationary in the rain for the first time today. Noticed a leaking A-pillar. Did you ever end up getting this fixed fully?
spdrcrx
Tom
Toyota 4runner
Mine was “fixed” according to the TSB. Sloppy job at best with the with 3M goo all over. Just rained and there’s still a leak although a little less than before.
spdrcrx
Tom
Toyota 4runner
Dealer visit #1: three days at the dealer to confirm there is a water leak and order parts for TSB.
Dealer visit #2: 2 days at the dealer to do the TSB.
Dealer visit #3: too busy to confirm water still leaking and asked to bring it back when the leak specialist was on site.
Dealer visit #4: confirmed water leak. Plan to redo the TSB but parts are on back order.
I guess there are too many Broncos with the water leak that they ran out of parts!
CaptainSolo
New Hampshire
2019 F150 STX
It’s an issue with the windshield seal. Mine was fine until a rock cracked my windshield and i had it replaced. there’s a setting pin that penetrated the seal when they replaced it and started to leak… profusely. I had Safelite come back and they took it off and reapplied the glass with a new seal, careful of the pin. No more leaking.
RioBlue1521
M
2022 Wildtrak
Mine leaks on the pax side piller, had water on the defrost vent, after reading other posts it may have dripped from the airbag. Also leaks in the back. Have only had it 2 wks on Friday.
KEM IA
Kevin
Cedar Rapids
Tundra
After hearing the horror stories I'm not going to worry about the recall if I see no issue such as water leak.
