Mpali
Illinois
2022 Wildtrak
My MIC top is actually very quiet. I have no wind noise what's so ever. But my previous vehicle was a wrangler so maybe I am used to a little noise.
RichWpg
Rich
San Jose
2022 2d Bronco
Great post OP. To those who think expectations are too high on wind noise, I think that's a bit silly given the $50-65k price point of the vehicle. This isn't rocket science, it's taking panels and seating them to a gasket. It's basic engineering. Either the specs on the parts are inadequate, the tolerances to which they are being made is incorrect, or poor installation at the factory. The Germans would be QA'ing with a trivial pressure test at the factory... Ford though? Nope, we are too good for that.
As a comparison point, I own a '21 Wrangler Unlimited as well, and the hard top on it, is fantastically better made. It's not even a contest. From the finish, to the fit/noise. The only spot the Ford top wins is the black fabric finish on the interior.
Perhaps they will fix this the 7g, who knows.
firefox33
Lincoln
Your photos show that your missing the C pillar inter molding. Just added a missing one on mine and it made a difference.
First photo, molding is missing, second molding is present, third photo is the part itself and last photo shows part location on the pillar. The part definitely fills a gap, see you photo marked with a yellow line. You can tell the part is missing without even taking the rear top panel off.
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found D61ADDE2-739F-4549-B1D8-26BAF097BE1F
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found 5D8BAE10-F57E-4809-A65A-F0B8AEE398C1
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found 5BDA8E22-E509-485E-AB01-BEE97AB36AA4
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found 3FBBE1D6-2E10-4D07-8B12-1204D1D5C8D9
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found C380B2F9-76F1-4DB7-A772-BBE93DABFCD8
mdfilip
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
I will have to take my roof off to see if those are missing
Ksjrb03
Tx
F250
Those are for soft top Broncos. Hard top doesn’t get them from the factory.
firefox33
Lincoln
We’ll I had one and now I have both and it’s quieter.
SnowBronco
Canada
I mix is pretty quiet overall now that I put the pool noodles along the sides.... It was starting to whistle in side winds... And it sounds like the shell and parts are chunking/shifting a little bit over off camber/angled bumps and coming off curbs and driveways. Anyone have that chunking sound yet? I thought it was just the cold. But it didn't do that shit last winter. Lol I checked all the bolts. They snug.
Skmac
Subaru Outback, Jaguar F-TYPE
Mine only has one really noticeable wind leak. Its worse on days with a crosswind. Sounds like its coming from behind the rear passenger where the rear shell meets the bronco. Maybe up towards the top. I have 4 door by the way. Its not horrible, but if i got that fixed it would be pretty quiet. Ill have to try these tips in spring.
I have the exact same area too, I coming up on for an oil change i was going to mention it then and let you know if they find anything
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
The only time Ive heard this is when there's been ice where the pieces meet. Maybe that your problem?
MudMonsterRacin
PA
Anyone else have these with a hard top? This may be my problem as well. Do you have pics what it looks like installed with the top on? This is where my wind noise is coming from. Do you have a part number for these if anyone needs them?
mike8675309
Minnesota
I know Ford will add a bunch of stuff to the Bronco and sell it for over 65K, but that doesn't make the engineering or the assembly line any better than what they did for the cheapest version of the Bronco. Expecting the experience of a 65k vehicle from a vehicle that has many versions below 40K is expecting too much.
firefox33
Lincoln
Most of the part is covered by the roof, only the one side shows that fills the gap. First photo is without the part and second is with.
Part numbers are:
M2DZ-78255A34-BA (RH)
M2DZ-78255A35-BA (LH)
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found 6005D95D-A5DC-47F3-AB66-4F5691886476
Ford Bronco MIC Hardtop 2.0 Wind Noise - Leaks Locations Found E8A9457E-62CF-4E0F-AA38-D269D3471D68
RichWpg
Rich
San Jose
2022 2d Bronco
That isn’t how the car industry works. When VW makes a Golf for 20k which they plan on selling for 45k at the GTI trim, they don’t tolerate garbage QA. The lower end models always benefit from the higher end models QA requirements, parts bins and platform which underpins them.
The problem with what Ford is doing, is it makes them very vulnerable to a new Jeep Wrangler model — which will come. It will have a fancy big screen, MobileEye IQ6 (2 generations newer), a gigantic petrol engine + electric options, fancy contemporary yet retro styling and yes….a top which has proper sealing. In fact, I can see Jeep going further and trying to make a too which is extremely well insulated/sealed to set themselves apart.
It just isn’t good business to ignore such a trivial problem. Especially on such a cash cow, with *potentially* rock solid loyal customer base. Why risk giving them reasons to shop around after the honeymoon period ends?
Skmac
Part numbers are:
Wait are we suppose to have these Parts?
