Modifying/customizing the Bronco after purchase voids the warranty?
BamaBronc
7/19 Purgatory
www.google.com
F150 and Edge
So I just talked to one of the guys at Long Lewis Ford and he said modifying/customizing the Bronco after purchase voids the warranty! Is this legit or partially true? There are so many people here I can hardly get a minute with the guy.
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
There are certain modifications that would void the warranty on any vehicle.
SillySpider
Rick
Washington
2015 JKU Rubicon / 2017 JK Recon
If that is true, they will be sunk by Jeep. Usually parts that are added are not covered, and if aftermarket parts cause damage, then that could void the warranty, but if the issues are unrelated, you should be covered. Aside from that, when I bought my JKU, Autonation told me that the Jeep was covered up to either a 4 or 6 inch lift -I don't really remember, I just remember it was well above what I was planning anyway which was a 2.5" lift. It's expected and almost culture to modify vehicles like this -it would ruin the brand.
Gamecock
That is effectively false. Obviously th e new pets aren’t covered, and if they specifically cause damage to another component, then that component isn’t covered, but the rest of the warranty is unaffected. Don’t believe that crap in general...mod away.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
The Bronco will surely be just like any other car.
Upgrade your radio but the the fuel rail goes? Fuel rail replaced under warranty.
Upgrade your fuel pump but the fuel rail goes? Fuel rail warranty denied.
Same thing goes for everything else.
I’ve definitely gotten into conversations with service managers regarding warranty work on my modified Jeep. Every once in a while they try to draw some weak nexus to something I did. They usually fold after some pushback, but other times I just have to eat it because ultimately I can’t always prove it *wasn’t* my mod that somehow lead to the failure of something else bolted to it.
In any event, I think what some Ford employees may be worried about is all this talk about “customization” and they want to make sure that people don’t believe that every Amazon item a customer bolts on will be covered under Ford’s bumper-to-bumper.
Theherofails
Thomas
Phoenix
Warranties generally cannot be denied or revoked completely.
If you use aftermarket tuning software and blow your engine, the dealership can void the drivetrain warranty since it was tampered with. Same concept applies to the suspension - if you modify it, you can't expect the dealership to fix your new aftermarket suspension under warranty.
What won't happen is your entire warranty is written off because of modifications. The dealership may tell you this out of confusion or a mistake, but its not quite correct.
https://www.consumer.ftc.gov/articles/0138-auto-warranties-routine-maintenance
In short, they can refuse to honor warranty on parts from a third party that you've installed to modify your vehicle, or the systems they directly interface with if said aftermarket parts were found to be defective or caused damage to warrantied systems. Modifying your drivetrain will not void your warranty on the electronics, for example.
UberGadgetFreak
Joe
Mt. Holly, NC
21 FE Bronco 22 FE Mav, 23 Mav Tremor, 03 Marauder
Magnusson-Moss Act is straightforward. Maintenance can be done by anyone. Mods can invalidate it if they can prove the mod parts were the cause. If they can't, then it should still be covered.
A55_CACTUS
D
KY
fv cars
Make them do it and then sue them if it isn't good
Bronco2021RV
Robert
Prescott Valley Az
Acura rdx
It is ALL up to the dealership your going to. Some are hard nose so far very fair. For the most part if you have a discussion with the service manager before you make changes to the vehicle in regards to those changes that you want to make to the vehicle you both will be on the same page. YES or nooooo
Judge Rufus
Wheeler
Colorado foothills
Infiniti QX80, GMC Sierra, Mercedes SLK32 AMG,
Pretty sure in our reservation agreements it clearly states that if you attach any license plate holder other than the Ford Performance Part license plate bracket then your warranty is completely void.
Drex
Jake
Parts or tunes may result in a specific claim being denied if it caused the problem, the entire warranty can only be voided in specific listed circumstances (like using it for racing.) Theory is they have to prove it caused the failure, however in practice, they put the onus on the owner to prove it didn't (it is more than mildly difficult to prove a negative...). If you put a non-sanctioned tune on it and they catch you trying to cheat them out of a repair of the drivetrain (including joints, mounts, and the like), you may out of luck. A low end repair that the dealer might look the other way on is possible, but if you blow an engine or transmission, Ford will spend the extra to pull your PCM and inspect for other modifications that might have caused it. Below a certain dollar threshold, it isn't worth the expenditure for them to go over it with a fine tooth comb.
PSUTE
Western Maryland
Sierra
So I can't add aftermarket running boards because it will void the warranty?...:rolleyes:...
Beachin 74
Delaware
If you use the wrong fasteners that don't play nice with aluminum and corrode the body, yes.
DaBronCo33
New York
Honda Accord
I think it would depend on the mod and the problem. Obviously you can’t swap out the engine and then try to get it covered by the warranty if you have issues with it. But replacing your hard top shouldn’t void an issue with the tranny.
