Theherofails
Thomas
Phoenix
Uh... If I was a gambling man, I'd say the labor cost on the airbag replacement on a MIC IP with seamless chute deployment/door is higher. It will most likely require the IP removal to get to it. Labor-intensive AF.
I work in Interior trim engineering.
I meant logistically, not physically. Modules are in VERY short supply. Boy would I love to pick your brain sometime.
Seatmandan
Dan
'21 Bronco, '11 Ford Edge, '10 Ford Fusion Sport
Good point- The way that instrument panel needs to be disassembled is: Topper removed, lower applique-finish panel removed, center console removed, glove box removed, THEN the major center finish panel assembly can be removed, which houses the airbag assembly.. It's not as bad as some others, but labor-intensive none the less.
EDIT: Keep in mind- the removal of each of those major components requires more steps within them themselves per each assembly.
SuperFord
2013 Ford Fusion
8/4 build date here (smack dab in the middle of the dates listed in the recall).
Still stuck on DM but not showing any open FSA’s on OASIS so far. 🤞
mpeugeot
Yep. Airbag recall is going to stop delivery on almost all the DM Bronco's.. Sorry, guys. The good news (not for you) is that new builds are shipping pretty quick right now.
The OTHER good news is that the airbag situation is much easier to fix, so I dont think you will have much delay.
If it was the controller module, RIP.. but I have yet to see any constraints on airbags.
Where did you find out how many were affected, because many in the date range are not affected. I don't know how many, but quite a few are not.
mpeugeot
I have an 8/13 blend date and mine also says NO RECALLS when I enter my VIN. I’d have thought mine would be part of the recall. Can we get some additional people to check and help confirm if we can trust this information from the Ford site?
It looks trustworthy so far. I was able to see dirt mountain Broncos both affected and uneffected that are still sitting at DMSC and untouched since 08/05 and 08/06.
1FMDE5FP9MLA20185 - RECALLED
Vs
1FMDE5CP2MLA76229 - NOT RECALLED
It also shows the same information in ETIS.
Drex
Jake
I just want to make sure i'm understanding this, you're upset that Ford is resolving a safety related issue on your vehicle, a device that may very well save your life or the life of one of your loved ones in the event of an accident?
This is truly a fascinating time to be alive.
Everyone else sees and understands it is being upset that Ford, with a lot less than full volume production and subsequently (should they have chosen to exercise it) much more time for QC per unit, failed to notice such a glaring error in a safety related issue in his vehicle that might have cost him or a loved one their life before shipping it out.
On the plus side, your interpretation allowed you to fire off a snarky comment that make the other kids snicker at the expense of someone else. That is really the important thing anyway, right? Perhaps you truly think people are upset that Ford is fixing a problem instead of being miffed that they didn't take enough care to prevent it?
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. 1966 Cobra 427 S/C replica
Don’t get too offended. He sends condescending snarky remarks to everyone. admins have been alerted. There is a pattern and other people complain about him too. Fortunately most people on this site are more mature.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
So, unless I missed something, the defect is that within the airbag unit, the bag was not folded correctly. Having removed my share of airbag modules in restoring a car, I do not recall having the ability to "see" that. The unit is exactly that, a unit from the supplier. They apparently realized a batch where this could be an issue, and notified Ford, who is now, responsibly, taking steps to replace them.
Yes, it sucks, but I did not blame BMW for the Takata FUBAR, not really sure you ought to be holding Ford on this, unless they are making their own air bag modules.
flip
Phil
IN
www.ruxerparts.com
Fords
Instrument Panel Center Middle Trim Panel
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
WARNING: The following procedure prescribes critical repair steps required for correct restraint system operation during a crash. Follow all notes and steps carefully. Failure to follow step instructions may result in incorrect operation of the restraint system and increases the risk of serious personal injury or death in a crash.
NOTE:
Removal steps in this procedure may contain installation details.
    WARNING: Before beginning any service procedure in this manual, refer to health and safety warnings in section 100-00 General Information. Failure to follow this instruction may result in serious personal injury.
    Refer to: Pyrotechnic Device Health and Safety Precautions (100-00 General Information, Description and Operation).
  1. Depower the SRS.
    Refer to: Supplemental Restraint System (SRS) Depowering (501-20B Supplemental Restraint System, General Procedures).
  1. Release the clips and remove the instrument panel lower center finsih panel.
Ford Bronco {thread} {filename}
  1. Release the clips and lower the steering column trim panel.
    • Disconnect the electrical connectors and fully lower the trim panel.
    1. Open the glove compartment.
    1. Remove the dampener.
    1. Release the stop tabs and fully lower.
  1. NOTE: If equipped.
    Remove the screws and the console handle.
    Torque: 48 lb.in (5.4 Nm)
  1. Remove the bolts, release the clips and remove the lower center instrument panel trim panel.
    • Disconnect the electrical connectors.
      Torque: 22 lb.in (2.5 Nm)
  1. NOTE: On both sides
    Remove the screws, release the clips and remove the assist handle.
    Torque: 80 lb.in (9 Nm)
  1. Remove the lower trim panel bolts.
  1. Release the clips and remove the lower trim panel.
    • Disconnect the electrical connector.
  1. Remove the instrument panel switch pack.
      Use the General Equipment: Interior Trim Remover
    Release the clips and remove the instrument panel speaker grille.
  1. Remove the bolt.
  1. Position aside the bolt covers.
  1. Remove the bolts.
  1. Remove the bolt, release the clips and remove the upper trim panel.
  1. Remove the upper passenger side air bag bracket bolts.
    Torque: 93 lb.in (10.5 Nm)
  1. Disconnect the electrical connector and remove the lower passenger side air bag bracket bolts.
  1. Remove the RH center middle instrument trim panel lower screws.
  1. Remove the bolts, release the clips and remove the center middle instrument trim panel.
Installation
  1. To install, reverse the removal procedure.
  1. Repower the SRS.
    Refer to: Supplemental Restraint System (SRS) Repowering (501-20B Supplemental Restraint System, General Procedures).
flip
Phil
IN
www.ruxerparts.com
Fords
Removal
NOTE:
  1. Ford Bronco {thread} {filename}
  2. Depower the SRS.
  3. Release the clips and remove the instrument panel lower center finsih panel.
  1. Remove the bolt.
Installation
  2. Repower the SRS.
Tadertodd
Todd
West Virginia
Two first gen Broncos and a second gen, 21 bronco
where did you check lol
one the pages, I cant remember if it was this one or one of facebook, some one posted about this recall and they had a link to enter the vin, it showed no recalls on mine
P52Ranch
Bryan
Oklahoma
2DR 7MT Badlands, F150 Lightning, New Holland 4030
Ford Bronco My Bronco arrived at the dealership.... but delivery hold due to airbag recall Hel
Removal
NOTE:
  1. Ford Bronco My Bronco arrived at the dealership.... but delivery hold due to airbag recall Hel
  2. Depower the SRS.
  1. Remove the bolt.
Installation
  2. Repower the SRS.
How much time does Ford allocate for this job? Seems to be very labor intensive.
flip
Phil
IN
www.ruxerparts.com
Fords
No repair info out yet which will have the times. My guess is less than 1.2 hours based on what the labor time guide shows. Realistically it's a two hour plus job.
