- Steve
- Aug 4, 2022
- 9
- 135
- 189
- New Jersey
- 2022 Bronco Badlands
- Badlands
Hells yeah I am in too!
I dont think so, but its 1 wire ran through the firewall plug to the switch wire of your choice.Has IAG updated their video to include how to connect to one of the AUX switches?
Wonāt work. Lights would be in the way of latch operation.Hey guys,
Curious... Has anyone attempted to install the 4 door hardtop set without the brackets? I understand that AIG advises to purchase the hardtop set with the brackets for the hardtops as its designed to bump out and widen the lighting assemblies from the recessed area on the roll bar with the intention of creating more space for ease operation of the latches for the hardtop panels.
That said, has anyone successfully attempted or do you know if you technically can install the set inside the recessed area for the hardtops without the brackets and it's just a little more snug next to the latches? Is that still doable or will the light assembly and latches interfere entirely with each other preventing you to do so?
I ask because having seen post installation pics from others , I honestly prefer the overall recessed look more so as to me, it stands out less and ultimately looks more Factory to me personally.
Thoughts?
Hmmm. Yeah that's what I was suspecting to be the case. Bit of a bummer. Alright thank ya for the feedback!Wonāt work. Lights would be in the way of latch operation.
The light would sit right where the rear panel latch isHey guys,
Thoughts?
If you donāt plan on removing the hard top panels, you donāt need the brackets. But if at any time in the future you want to remove the panels, the latches wonāt clear the lights.Hey guys,
Thoughts?
I had the same issue and I put a washer on and still had issues. I ended up putting the ground between the chassis and that bracket. That instantly worked for me.It still seems weird that I seem to be only one that had an issue with the ground. I had to take back apart and add a washer between the vehicle connection and ground wire as for some reason when simply tightend as video shows my ground changed to not "solid" and light output changed to about 5%. When slightly loosened got full power but of course driving it would move and then no lights. On 2 days with washer and working so far. Not sure why mine has this issue.
