Panda Motorworks Ford Bronco BPV Delete Kit
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Thanks Chris. Hopefully I didn't come across the wrong way (tendency to do that).
I fully appreciate the tech and how-tos and learning about these blown motors (note to supercharger people - they are both blown).
Keep safe out there!
Not at all!
That's what we are here for is to provide great support and service!
ChetC
Las Vegas, NV
2022 Big Bend
Rarely, if ever, do you hear anyone refer to a turbocharged engine as "blown". I'm not saying you're wrong, I'm just saying you're not going to hear industry people refer to a turbocharged engine as being blown unless the pistons are hanging out of the pan or side of the block.
Source- have been a motorsports announcer for more than 20 years.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Not everything needs to be done to increase power. This is a nice simple kit, that for the money is worth it, if it's your bag of tricks. Who didn't like a playing card on the spokes when they were a kid? Lol.
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
bigblueboing
Keith
Los Angeles.
Forester
One of the best things about owning a turbocharged vehicle is hearing the turbo! In stock form, you can faintly hear the turbo on the 2.3L. If you're a fan of the turbo blow off valve "Whoosh", but don't want to break the bank than this thread is for you! The factory bypass valve recirculates back into the intake box to minimize the "Whoosh". With our kit, you are simply disconnecting the recirc tube and capping off the port on the airbox allowing the bypass valve venting to atmosphere resulting in the turbo whoosh! We sell the kit for only $5, so it is a risk-free option to see if you like the turbo noise and potentially upgrade to an aftermarket blow off valve in the future!
Grab yours today by following this link---> https://www.pandamotorworks.com/products/panda-motorworks-bpv-delete-kit-ford-bronco
Now that we've discussed what the BPV Delete kit does, let's hop into installation! You can follow the step by step instructions below to see how truly simple installation is.
Tools Needed:
-Pliers
-Sidecutters
-Flashlight
Estimated installation time: 5-10 minutes
Step 1: Remove hose clamp from Bypass Valve
Step 2: Pull hose off Bypass Valve
Step 3: Follow recirc hose to airbox connection
Step 4: Use pliers to remove hose clamp
Step 5: Pull recirc hose off airbox connection and remove entirely
Step 6: Take provided cap and install on airbox connection
Step 7: Take provided cable tie and lasso
Step 8: Install lasso'd cable tie around the cap and pull tight to ensure a secure connection
Step 9: Use sidecutters to trim excess cable tie
Step 10: Put tools away, and enjoy!
One of the cool things is that the bronco has the BPV on the top of the motor.
I heard GFB(go fast bits) is developing a BPV mod that’s better than stock. Doesn’t really add noise but makes it stronger for tuning
BC33
Brandon
RI
Wrangler, Ram 1500
How about if it was supercharged?
ChetC
Las Vegas, NV
2022 Big Bend
I’ll play your silly games. Crank driven supercharger… is that a blower motor? Blown? If you buy one, are you putting a blower on you car?
texasgreazer
Burleson TX
2020 Explorer, 2019 GMC Canyon
<<< subconsciously wonders if this would work on the significant others 2020 Explorer-and would she notice?
St. Louis
They will come out with something for sure! Great products we stock them here at Panda
