- Banned
- #196
I look forward to my weekly upstate trips for work, fill her with 94Yes, it will be slightly more aggressive with 93 fueling.
@LethalPerformanceHere’s a great review that Krista Pickens aka Buckle Up Buttercup did on the 2.3l cal.
Let us know if any of you guys have any questions. Thanks!
While it hasn't been tested, I don't see any issues running the Pedal Commander on top of the FPP tune. That being said the FPP flash increases throttle response as well, so the commander may end up being redundant depending on how much you're increasing the sensitivity already.@LethalPerformance
Was going to order off the site, but wanted to see if you heard of any issues with running this with the Pedal Commander? Can you run both at the same time? Any insight on this would be helpful. Thanks!
Wish I would have seen this sooner. I just put rough country speedometer calibration on ‘23 2.3l base. Can you run this with that installed?While it hasn't been tested, I don't see any issues running the Pedal Commander on top of the FPP tune. That being said the FPP flash increases throttle response as well, so the commander may end up being redundant depending on how much you're increasing the sensitivity already.
I also have an 23 everglades on the way and wondering if the tune will work.I keep getting an error code and this is through the dealership. Any advice?
Yes, I don't see why not, but it will also be redundant. I'm not sure if the Ford flash would overwrite that or not, maybe a ForScan expert can chime in.Wish I would have seen this sooner. I just put rough country speedometer calibration on ‘23 2.3l base. Can you run this with that installed?
If you're not in CA then it will work. CA vehicles won't be able to receive the Ford Performance calibrations until they receive approval from CARB.I also have an 23 everglades on the way and wondering if the tune will work.
Because the atmosphere within the engine bay of your Bronco has completely collapsed and you're running on pure dark matter.Can someone tell me why my boost is showing as -130 on the module?
How would California know if said procal was installed..If you're not in CA then it will work. CA vehicles won't be able to receive the Ford Performance calibrations until they receive approval from CARB.
I think that because it's VIN-locked, Ford cross references your VIN with your registration and won't allow the software to upload onto the box until CARB approval.How would California know if said procal was installed..
