Can't speak for kodiak, but the size I want are only available in E, 255/80x17. Also, I've never had a tire ruining or even very many tire flattening events with E's. Had them on my LJ, rode fine, yeah fine...it was a Jeep after all.I understand that you guys feel that the sticker is sufficient but unless you replace the stock tires on you vehicle with the same tire or a tire with very similar load numbers (weight @ psi) the sticker is no longer the go to.
Had you done the math, chalk test or both, you may have found those tires would have road a lot better than they did. Of course there is a window of acceptable inflation.
For the most part, stock tires and aftermarket A/T and M/T tires have very different characteristics.
@kodiakisland curious why you’d want E rated tires for a bronco. (No judgement. Just curious)
