Pros and cons of factory hitch vs. aftermarket?
Jmax
Plymouth
Explorer
Is there any reason to do factory hitch vs. aftermarket? Pros/cons?
Daktari
Oliver
after market will most likely be cheaper but probably won't look as clean. I have zero interest in installing anything myself and really don't want my new ride in some shop shortly after finally getting it, so I ordered from factory. On my Tacoma I had it installed afterwards and the cable harness just hangs around under the truck and some control module was attached with double sided tape that long gave up, just zip tied to things.
From ford you get the two sockets (4 and 7 leads I think?) nicely installed with nice little doors over them, making it look clean.
But it's easy to get later on. Uhaul and others, I got mine where I got my camper shell for the Taco.
Tilzbow
NV
GM Sierra Diesel Pick Up
Not having to deal with a poorly installed wiring is the number one reason not to go with aftermarket
Virtual-Chris
North Vancouver
Depends what you’re going to use it for...
- A bike rack? Go aftermarket.
- A trailer with brakes? Get factory and Ford trailer brake controller.
- A utility trailer with no brakes... toss up.
Southside_Ray
Ray
Iowa
2014 Ford Fusion
As someone who is going aftermarket (base) I would probably say the wait for an aftermarket solution will probably be a con.
Gamecock
The biggest con for many aftermarket hitches is that they don’t tuck up like the factory hitch and cost you in departure angle because they hang so low. They catch on things. The factory hitch is perfectly out of the way.
Wanted33
Down south in Dixie
That right there is my feeling to the tea. Yes it's cheaper to go aftermarket, and that's what I've done with all of my trucks. But, I just don't want to mess with it this time. Guess I'm getting lazy in my old age. :)
SEkevin
Kevin
Sleepy Eye, MN
Explorer
I will only use for bikes so I pulled hitch from my order. Checked with dealer and hitch would be $400 thru them.
rws
Robert
GA
2015 VW GTI, 2018 Silverado 1500 LT Z71
Not once, while installing an aftermarket hitch and wiring, have I said to myself, "man I'm glad I didn't get the factory hitch and wiring". Essentially, in my experience, the cost differential between factory and aftermarket is minimal, if you value your time to install, etc.
I've added it to my build... if it means a delay in delivery, that's a delay I'm willing to live with :)
flip
Phil
IN
www.ruxerparts.com
Fords
Four bolt install. The issue will be if you need trailer braking which will be more involved if not OE. If you just need for a rack, four bolts, drawbar, done. No need for trailer brakes then flat 4 pin for turn, stop, and marker lights? Still have to figure out if you can tap into existing wiring with a kit or if that is going to cause problems with factory lighting. We've seen a few cases where trailer lights were tapped into factory rear lights and it caused lighting control module problems due to the additional load. Most of the stuff anymore is controlled by modules that get a signal from a switch or sensor to activate whatever. These circuits are closely monitored for loads, resistance and shorts to power or ground.
It will get figured out pretty quickly by the aftermarket but for the sake of the question, I would try to get an OEM hitch if possible due to the simplicity of it as well as carrying a part warranty. Make sure you use the OEM hardware too.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
This topic has been discussed ad nauseam...
....all I will say is, if you are at all interested in the 7-pin connector, or adding a trailer brake controller, you should just get the factory package.
If you are NOT interested in any of that, it will most certainly be cheaper to do it aftermarket... but you have to wait for aftermarket to be available, and you have to weigh how much work you want to do yourself and whether that time is worth it to you.
Lakelife36
Ben
Interior of BC
If you are interested in any of that, it will most certainly be cheaper to do it aftermarket... but you have to wait for aftermarket to be available, and you have to weigh how much work you want to do yourself and whether that time is worth it to you.
👆🏻 add a "not" after the third word of the second paragraph and you have it all right here. For further discussion read the other threads on this exact topic in the towing forum.
reidski29
Reid
Grand Rapids, MI
2013 Ford Expedition, 2018 Santa Cruz Blur
I still can't believe the trailer hitch isn't welded to the frame. My 2002 Trailblazer had a trailer hitch from the factory welded into the frame - in fact all Trailblazer/Envoys did back then. I kind of expected that to happen with the Bronco.
Can't believe it is held in by 4 measly bolts...
