Aman
Aman
Northern NJ
The smittybilt only needs longer cables. I went with the Warn kit cause the price wasn’t bad, decent length cables and the rubber end caps were black. Didn’t want red and yellow on my front bumper.
WARN 89960 ZEON Control Pack Relocation Kit
This is the same kit I ordered. Smittybilt recommended 3 AWG cable to relocate the solenoid. I couldn't find the specs on the WARN kit, but figured I would take a chance. When it arrived, I was pleasantly surprised to see they use 2 AWG cable.
The terminals on the X20 Gen 3 are on top of the motor, so unfortunately it won't look quite as clean as yours. The control box is configured differently as well, but it should still fit on top of the engine bay fuse box...once I relocate the Panda module, that is.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 84C039D9-623F-4953-B37E-2F2EDC5E5154
66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
Do you have the ACC? Does it still work?
ACC works great... without modifying or relocating ACC radar sensor.
Parking sensors work after relocation with RC mounts. (Initially threw some error codes but I did some aiming and troubleshooting... no problems since).
I'll take some pics of the relocated camera angle later today.
BroncoSarge
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
Looks GREAT! This is the only way to go. The control box takes up so much room on top of the winch and blocks so much grill.
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
On parking sensors was it actual on screen errors or did they just fire randomly?
BroncoSarge
BroncoSarge
Jeffrey
I had to turn off and on my parking sensors in the radio. Worked fine after.
66GT
Thomas
Tacoma, WA
Some crazy shit.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220621_184529
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220621_184712
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220621_184727
Swapped which side the sensors were on.. problem followed the sensor.. was careful to align the sensors directly forward... problem became intermittent... and eventually went away.
66GT
Thomas
Tacoma, WA
@Hossamus Prime @Raskew @ne2000 @Razorbak86
No issues at all with relocation or camera angle. I'm chalking this one up as a success.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220807_203117
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220809_201503
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220809_201514
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220809_201608
akturbo
Seattle Eastside
That is awesome, looks so much better!! I was super excited to try this until I realized you don't have a lightbar in there.
I do not like how mine looks on the front. The camera bracket and kit is top notch quality, just not for me.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 1660104862085
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 1660105056484
rainman23
Ray
Salem, OR
F-150
I apologize if I missed it, but where did you source that camera relocation bracket? That looks great (and appears to function just as well)!
66GT
Thomas
Tacoma, WA
I wasn't a fan of the RC light bar... and I liked the way the RC grille resembled the Badlands grille... so at first I mounted a "stealth" light bar behind the RC grille.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220702_165159
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220702_164903
I needed to move the control box (cooling issues)... and I needed to solve the camera issue. I figured I could always put lights elsewhere... but there was only one place I wanted to put that camera. I've got another set of pods for my cowl to replace the light bar from the winch.
After a lot of different configurations, I'm finally satisfied where I'm at.
66GT
Thomas
Tacoma, WA
My garage... lol.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220806_154709
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220806_171722
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220806_171800
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220807_144451
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220807_141715
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220807_141828
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220809_201025
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
My garage... lol.
any details on what cable you used?
i have a JCR relocate bracket coming but it would be much easier to build somthing.
66GT
Thomas
Tacoma, WA
Tecreddy Fakra Z Female to Female Car FM Adapter Cable 6.6ft for Volkswagen/Audi Car GPS Navigation FM AM Radio TEL Telematics Bluetooth Module XM Satellite Radio, 2m https://a.co/d/buffvht
I just coiled the excess at the top of the core support. It would have been easy to extend the washer hose as well, but cutting the hole to fit that would have gone below the bottom of the lower support. I just unclipped the nozzle from the bottom of the camera and capped off the line with a rubber vacuum line cap.
Mikerider
Washington
fantastic thank you!
