MysteryCamper
TX
2021 Bronco FE, 2000 Jeep Grand Cherokee
Made a short video to show how easy it is to pop the vents out. Great to know in case you want to swap for different colors or if you break one.
MysteryCamper
MysteryCamper
TX
How about removing the little chicklet or tic-tac part? I haven’t worked up the nerve to pry on the vents yet, so thanks for this.
The vent insert comes apart pretty easily as well. There are little clips at the top and bottom that snap apart (be gentle, they don't seem very sturdy). I haven't looked at just the little tic-tac part, but the insert can def be removed.
dcaero
Bronco OBX SAS
Just for information as I have replaced my orange inserts with grey inserts, the two outboard vents are smaller than the two inboard vents, helpful to know if you get some new vents and go the hard route and take the dash apart to swap pieces, not that that happened to me.......
All the colored grip portions are the same size however. They're very easy to remove you just have to gently pry up on both top and bottom at the same time and it should release very easily and slide off. It c-clamps onto the middle most blade on top and bottom with little fangs. There is even a centering guide so you can't put it on upside down.
Make a quick 30 second video of it and this thread will be complete!
604Bronco
British Columbia
www.bronco6g.com
Thanks for sharing this. I would recommend a trim removal tool instead, so you don't damage anything. Been there, done that lol.
Zenpher
Aaron
Irvine, CA
Jeep Cherokee
Love this! Been waiting for someone to explain how to remove all the colored accents from the Bronco.
Where did you purchase the different colored version for the swap?
Broncola
Hawaii
Element, ‘75 Bronco widow
Just need a candy company out there to start selling some chicklets, tic-tacs, and nerds.
Toccoa
Isuzu Rodeo Sport
This might open up more packages for people to choose from. It's more than annoying that Ford tied interior trim colors to packages.
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
ChrisCozart
Hickory Creek, TX
2022 Bronco Black Diamond (non-Sas.)
now this thread needs a spin off thread for members who want to swap vent inserts to better match their rig color.
JTBros
Long Island, New York
GR Corolla
Gouge across my dash hood says hello lol
