Roof Rack unavailable on Sasquatch because of factory tire's weight capacity ?
Techun
Pa
BD, 2.7, MIC, 4dr
It's not the tires, they're just using that to denote the sasquatch package as a whole.
In that document there is a field for how much accessory weight they allow for each trim. For first editions it's very tiny.
cgguy68
Mobile, AL
2002 Ford F250
We've all seen multiple posts and discussion on the inability to put a roof rack on a Sasquatch package . They're pretty clear that it has to do with weight capacity , but it may mostly be the tires!?
So, if you look at pg. 12 of the Bronco Equipment Installation Guide, theres a table on Roof Rack
Load Capacity:
In motion: 110lbs
Stationary: 450lb
315/70R17 tires: 0
An Explanation: If you look at the specs on those Goodyear Territory tires, you'll see that they are the softer "C" rated tires, with weight capacity of a measly 2535 pounds! Thats weak for a loaded vehicle, same as the stock OBX tires. But that explains the capacity issue, ITS THE TIRES! A fix would be to upgrade to an E rated tire, get a rack, and move on. Im guessing that the suspension components are pretty beefy, the tires seem like the weak link in the design chain. E rated tires are heavier, and a harsher ride.
Clearly Ford wants its Sasquatch to be comfortable, and this may be part of the design compromises on a vehicle with 35" tires (actually, Theyre 34.4" tires) extra machinery, armor plating, and soft tires . . . When theres the extra weight of 4 doors, 2.7 engine, auto trans
Any thoughts?
I would go to D rated and not E rated.
cgguy68
Mobile, AL
2002 Ford F250
Max PSI of 35?? Get outta here...lol
Where the fuck did you get that?
The recommended normal, everyday PSI for a Sasquatch equipped Bronco is 39 psi
From the side of the tire.
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. 1966 Cobra 427 S/C replica
Yeah the fact that you can get a roof rack on a 2022 wildtrack with 2.7 and hard top seems to blow this idea out of the water because the tires are unchanged (so no, it's not an issue with the tires.) To me - it looks like someone in corporate simply changed their minds about how they do the calculations. Or, it actually had nothing to do with weight all along. After all - the whole idea is that you put stuff on the rack. So it's hard to believe that the rack itself puts the weight over some threshhold. I don't believe that we've been given the "real" reason.
WuNgUn
Ontario Canada
2 door Squatched
I haven't axtually seen this myself. Tire Rack says 35psi. Other size Territories have a max pressure of 50psi, which sounds about right.
I DO know that the OE Territories on the Bronco are not the same Territories on the TTC or other vehicles, regardless of size...
With that said, there is no way Ford would recommend a tire pressure higher than what the tire manufacturer says is safe. Lol
Draughon
Daylon
Dallas
BMW 4-Series
My ideal would be a 4dr that keeps the rear cap on, and has a soft top for the three removable panels, over both seat rows. Then, a small rack cage on top of the rear cap, like the OBX concept vehicle, with a larger front soft top
That's exactly what I'd want on my 2-Door badlands... just a little something on the rear for light loads.
cgguy68
Mobile, AL
2002 Ford F250
Mine on my sasquatch say 35 psi on the sidewall.
lakesinai
lakesinai
Charleston SC
It seems it is weight, because you cannot have the Wildtrack roof rack IF you also order the metal steel protection. . . The wildtrack configuration just allows you to choose your weight poison
lakesinai
lakesinai
Charleston SC
There is a fine print note that says up to 10 psi additional inflation permitted.
Ford Bronco Roof Rack unavailable on Sasquatch because of factory tire's weight capacity ? 20211017_110346
Well golly gee! This just has layers and layers of truth!
lakesinai
lakesinai
Charleston SC
I was thinking i might put the MIC panels up there when driving for the day on the beach!
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
Load Capacity:
In motion: 110lbs
Stationary: 450lb
315/70R17 tires: 0
Any thoughts?
From what I hear, you don't want the E tires if you are going to deflate for crawling. Sidewalls too stiff.
lakesinai
lakesinai
Charleston SC
