Rusting accessory bolts
KPLOBX
Kristopher
Savannah GA
Jeep Wrangler TJ
Every Bronco on the lot here had rusty bolts. It’s unbelievable that something like this, so simple and avoidable gets through. It makes you wonder what other quality issues are lurking. Ford must be spending a fortune fixing these
Deleted member 32220
Guest
Mine was built today, I should see it by Wednesday convoy to NY. I expect nothing less than rusted bolts, among a whole host of other problems😕
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
Also, BroncoGraveyard has these, and they come with really nice stainless steel hardware.
https://shop.broncograveyard.com/2021-Bronco-Flag-Mount/productinfo/B147100/
I powder coated the SS bracket black to match sights.
Those brackets are great but they cover the slot in the trail site... I would mill a slot out of the bracket so you can still use the trail site as a tie down location and then I would use the bracket as a attachment point for limb risers. If I ever need a flag I would put it on the back.
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
Hit the bolts with some black spray paint
Matt J.
San Francisco, CA
‘97 4Runner SR5 5sp manual, ‘22 4dr BadManSquatch
Same thing happened to me. Vehicle was delivered on 3/25, picked up on 3/26 and I noticed the rust right away.
Ditto re recon1126 post, can someone share the size of the bolts? I don't want to leave them on the truck and risk discoloring the plastic and finish...
Thanks!
Ford Bronco Rusting accessory bolts IMG_9665
Ford Bronco Rusting accessory bolts IMG_9666
Gotdesl
Alan
Rifle, CO
2016 Ram 3500 Megacab 4x4
I've got some rust going on with the Bronco bolts, but it's not the trail sight ones. One of my black A pillar bolts is rusting as are the ones holding the driver's side interior grab handle. Being western Colorado, these things aren't seeing much in the way of moisture or humidity. Ford really needs to make the hardware available as the "Bronco" bolts are a pretty big part of what makes it unique. I think Ford saved a few cents where they shouldn't have.
VGK_Fan
Henderson NV
2024 Audi S5 Sportback, 2021 Bronco Badlands
Ford Bronco Rusting accessory bolts schleprock
Mjolnir
Cash
Georgia
2022 Ford Bronco
If any of you figure out the solution for replacement bolts, please do share. My dumb self over here had 3/4 components on one side rusting so I took them off and left the one female bolt sitting there on the bronco while I repainted the others. Yesterday I came home from work and couldn’t resist switching to the Bronco, forgetting I removed the bolts, to go back into town with the nice weather and now that bolt is lost to the streets 😓
10K_Vet
Ron
Bossier City, Louisiana
2007 Dodge Ram 1500 5.7 Hemi
Mine were doing the same, rusted at pickup. It wasn't worth the gas to drive back to the dealer.. I ended up sandblasting mine and putting them in with a batch of powder coating I did over the weekend.
It won't take much to rattle-can them as well. If you go to the hardware store, good luck finding a flush-mount hex stamped 'bronco' :)
Rattle can mine after wire wheel/brush the rust off.
Chelada
Bulverde, TX
2022 Bronco
Posting my bolts here with the same issue. I know I can throw them in a bottle with vinegar and spray with WD-40 but I feel this needs to be addressed after taking delivery just a month ago. Going to the dealer at lunch today to see what they say.
Ford Bronco Rusting accessory bolts 9E7932A9-E9C3-4135-A342-8CD9102CE07F
RUZ
Arkansas
2006 F150, 2020 QX80
I experimented with some cold blue. Hopefully it lasts a while.
Ford Bronco Rusting accessory bolts 20220427_174757
TX-Hans
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
Just went out an checked mine. No rust. They must have the correct coating because where I live we get a ton of fog based on the marine layer and bare metal rusts rapidly.
