Seeking assistance with the M190 to M210 upgrade issue
brockbrock
brock
raptor
bronco
Hello everyone, I would like to replace the front axle of my Bronco Base with the M210 version. What is the purpose of the component on M190? After replacing it with M210, how should I handle the original plug?
Ford Bronco Seeking assistance with the M190 to M210 upgrade issue 微信图片_20230916110050
Ford Bronco Seeking assistance with the M190 to M210 upgrade issue 微信图片_20230916105555
builtMIbronco
Zach
Hillsdale Michigan
22 Black Diamond on 37s
That's the Front-Axle Disconnect/FAD. Zip tie the old, unused plug out of the way. I raveled mine up as far as I could pretty much to the firewall and zip tied it behind the fender liner.
brockbrock
brock
raptor
bronco
Thank you for your response. So, can I simply replace the M210 front axle directly without worrying about these wires and just bundle them up? Will it throw any fault codes?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
You can use Procal to program for FAD delete instead of wiring extra parts up.
builtMIbronco
Zach
Hillsdale Michigan
No, you'll need the ford procal tuner to disable the FAD or you'll have codes. Once disabled those wires don't do anything though and you can ravel 'em up like I was saying.
brockbrock
brock
raptor
bronco
Understood, but I'm in China, and Procal can't connect to the server for updates. I can only modify some of the car's settings. I wonder if there's a way to solve this?
