- Ken
- Jan 24, 2022
- 95
- 2,463
- 3,169
- 90Bronco19
- 2022 bronco outer banks
- Outer Banks
- #121
I could not get my Amber ditch light to blink properly no matter what the setting. I believe we have the same lights. Mine would do okay for 5-6 flashes then so quick flashes then go back to normal. Do you have them just triggering a relay? Or directly to the light?So, Finished all I'm going to do playing with this on mine..
I pulled the Turn Signal Pins out of C1400/C1401, and used a weather pack Pin connector on the wires going to my ditch lights, plugged them together and covered them with Heat Shrink;
Not the way I wanted to do it, But should be well protected, secure, and easily reversible.
Also traced out the wires to check... On my late manufacture (11/21) Badlands, The Turn signal wire Does come from the Door Control Modules, not the PCM/BCM. The Spot and Puddle lamp wires end at C203 and C207
