Soft top issues - wind noise from my rear passenger door at 40+ MPH
MrDrProfJon
Jon
Bronco Outer Banks
Maybe someone else is experiencing what I am..when I get up to about 40+mph I start hearing noticeable wind noise from my rear passenger door. The best way to describe it is it sounds like the window is barely cracked. I thought maybe the top wasn’t tucked right or velcro not attached so I took the top all the way down and put it back up. It did nothing. It’s extremely annoying, very noticeable and I’m not sure if the dealer will do anything about it. Anyone have thoughts?
Jazer
Jessica
2.7 OBX
Soft top does have areas where the wind can get through. Few things I would check: Make sure when it is closed it is latching properly at the B pillar. Sometimes the little hooks don't grab all the way, especially in the begining (not the main latches at the windshield, but where you squeeze the lever to move top from position 1, to position 2/all the way down). If those are latched properly after bringing the top back up, check to make sure the cable is sitting in it's bracket properly. Same area.
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
MrDrProfJon
Jon
Bronco Outer Banks
You said make sure the cable is in the right spot, are you referring to the cable that is used to connect the B pillar lever to both sides of the bronco?
Jazer
Jessica
2.7 OBX
Yeah some people have had the cables not seated properly, and I would imagine this could cause inappropriate tension.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Any pics of what this entails? Having trouble picturing it.
In any case, OP, yes, I'm having the same, and to the best of my knowledge the middle latches are fully engaged. ¯\_(ツ)_/¯
Jazer
Jessica
2.7 OBX
etmccaus86
Evan
Motor City
'22 BaseSquatch
Mustbeheresomewhere
Micah
2012 Chevrolet Silverado, 2022 Bronco Badlands 4D
Make sure that the window is closing all the way when you shut the door. Sometimes it “forgets” to go up when you shut it.
To fix it, roll it down all the way and hold the button down for a count of 5, then roll it up and do the same thing. That might be your problem. I absolutely love the soft top, hope you do too!
MrDrProfJon
Jon
Bronco Outer Banks
I know what you mean, however it doesn’t sound like it’s EXACTLY coming from the window. Almost like it’s coming from the door jam, above roll cage area
MrDrProfJon
Jon
Bronco Outer Banks
Of course it’s raining right now in my area lol so I’ll wait until it stops to put the top down and check the wire and seals
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Jon. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Potroast_Jr
Louisiana
2023 Bronco
Sorry to necro this thread, but did you ever find a solution? I just got my '23 a few days before Christmas and I have this noise exactly as you describe it. For reference, I drove a '21 soft top for 9 months and never heard this much wind noise. Not even close.
MrDrProfJon
Jon
Bronco Outer Banks
Basically I was told by Ford to deal with it and it’s normal. Do I agree with their decision? No not at all. Wind noise inside a cabin should never be considered normal. However, a buddy of mine let me drive his bronco (same exact spec as mine) and I heard the same exact noise in his. So I’ve learned to deal with it by turning my music up louder lol
