Soft top rear window failing!
BroncoPVC
Paul
Seattle
2021 Bronco Badlands,Sas, 4dr, Soft Top, Rapid Red
Has anyone had an issue with their soft top rear window pulling away from the fabric like mine? I've searched and can't seem to find the same issue reported elsewhere. I took delivery three weeks ago, I've put 1,200 miles on it (actually only 1,100, it came with 100 miles on it from the dealership) and already have an appointment with the dealership for other reasons. Yes, it's been a ton of fun and I feel lucky to have it but this can't be normal wear and tear. I've only had the top all the way down twice so I know it's not from that. It just seems like the adhesive is failing and the plastic is separating from the fabric. Anyone seen this yet?
Ford Bronco Soft top rear window failing! 20210901_182556~3
Ford Bronco Soft top rear window failing! 20210901_182556~2
Zeke013
Oregon
Ugh. Sorry. I am assuming you haven't folded it all the way down with the rear window in place. I wonder if anyone else did in the first 100 miles . . .
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
This is exactly what warranty is for. I wouldn’t sweat it.
BroncoPVC
BroncoPVC
Paul
Seattle
100 miles from the dealer? Why?
Great question! I pressed the dealership for an answer and got zero information. They say that's how it came. I've heard of folks taking delivery with around 40 miles but nothing like 100. It was actually 108.
BroncoPVC
BroncoPVC
Paul
Seattle
Well clearly. I suppose I meant that I haven't removed it more than twice. I imagine removing time and time again could cause wear and tear but its basically been stationary the whole time.
BroncoPVC
BroncoPVC
Paul
Seattle
I'm not too worried about it at the moment. I'm hoping Ford does the right thing but I'd be lying if I said I wasn't concerned with the long term durability of the product. Also I'm a little concerned that the dealership might just want to "fix" the current panel instead of replacing it.
HotdogThud
mk6 gti, '21 MoarDoor
I wouldn't either, but then again, most dealer techs are gonna look at that, throw some Elmer's rubber cement on it and call it done. Then send Ford the bill for warranty work.
Bronco cat
Carl
Morgantown wv
Or order a new panel which is what I would make them do
Bronco cat
Carl
Morgantown wv
FYI the company that makes the top is American and it’s made here.
Haartz is a top supplier of convertible top and interior materials to the auto industry and just so happens to supply top materials to a company named Jeep who makes a vehicle you may have heard of called Wrangler.
mC.242
2021 Big Bend 4dr (sold)
Mine also had 100 miles on it when I took delivery. No explanation why either.
Jp215
James
Pennsylvania
2015 F150
As a ford dealership technician i can say it’s not uncommon for there to be what some would consider excessive miles. Occasional ford will randomly select vehicles after being built for an extensive quality control test of things like the suspension. Also with all the delays and that flooding Detroit had a while back they probably got moved from storage lot to other lots.
acnp2022
CT
ford
No issues yet with mine and I have driven hours at 70-80mph with the top down and the wind hitting the back window. Hopefully that is not a common occurrence
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Any evidence of a break in attempt? Other than that you’re doing the right thing. They should fix it under warranty
