Moto26
Tucson AZ
Please change the original title post back to Soft top is melting! :)
The OP has no control over that. The admins will come in and change the title, either because it makes the problem more clearly understood, or because the original title makes F**d look bad.
Kinda like how they’ll add “warning, no politics” on threads where people are definitely going to keep bringing up politics until the thread gets shut down. Which it does, every time.
Jarmo Karhu
Jarmo Karhu
Long Beach, CA
Buick Regal
It's funny how your so willing to help here but when you actually get in the dealership the answer is "they all do that" or some other idiotic response. I brought mine in for an active TSB on the soft top scratching the roll bar & the dealer tried saying it was my fault? Then they say they cant hear a soft top rattle that even Hellen Keller couldn't miss. Ford Dealer level support never fails to surprise me.
That’s the same canned message I got when I originally posted. I was issued a case # and told to take it to a dealer for inspection. After that, crickets from both the dealer and @fordmotorcompany. I called corporate in Dearborn after the dealer fiasco. Been communicating with them since.
Plaidfinger
CO
2022 Bronco Big Bend 4 Door Sasquatch, 2021 Mach 1
RCVBAF
Brett
Caddo Mills TX
2020 Explorer, 2005 Ranger FX4, & 2021 Bronco
Hey there. I'd like to see what I can do to assist with your Bronco's soft top. Can you please send over a private message with your VIN and the name and location of your local dealer so I can start looking into this on my end?
Mine is separating as well. Please let me know what I need to do.
RLW
Robert
Chattanooga, TN
2000 Lexus GS 300, 2022 Badlands, 2022 Honda Odyss
I haven’t had this particular problem with my soft top.
But I did have the tension cable break. Actually it was the anchor/bolt holding it that broke.
I took it to the dealer. The dealer took it to a local soft top specialty shop here in town.
All fixed under warranty. Maybe your dealer should do something like that to fix this problem.
lonediver2002
john
Palm Bay, florida
Mine is starting just above the front seats and at the front end of the top above the mirror. Will be taking it to Ford to have them fix the issue.
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
PSA, the company that cannot make MIC hard tops made the soft tops as well. QC is not their hallmark in manufacturing.
ct1975
2017 Fusion, 2020 Navigator, 2002 Mustang GT
flip
Phil
IN
www.ruxerparts.com
Fords
My suggestion is to take to your dealer so they can document and take pics for prior approval if needed. Don't give Ford or dealer a reason to deny coverage because you blew some 3M trim adhesive on it. There's no procedure in the manual to address this. Usually they will list a specific lube, grease, sealer or trim adhesive to do certain repairs. I'll bet we see a TSB on this fairly soon but in the mean time, the only "correct" repair procedure is canvas replacement. Very important dealer documents this prior to doing anything because these are expensive and no one wants to fight a chargeback because asses weren't covered.
dwfern
Dearborn, MI
Bronco 4-Door
I noticed this happening on mine as well around March-ish.
I spent the winter in Florida and put the top back daily. When this started happening I chalked it up to sitting in the hot Florida sun and the more humid weather causing the glue to soften.
Once I got back to Michigan in May, the weather wasn't as warm or humid and I have not noticed it happening as often.
dwfern
Dearborn, MI
Bronco 4-Door
Happened to mine, got some Gorilla spray adhesive, problem solved.
How has the Gorilla Glue Spray been holding up?
JRS993
TN
Subaru
I had the same condition on my soft top. I've used 3M Super 77 on other upholstery projects and used this to fix that interior top backing issue seen in the photos. I used a piece of cardboard to mask off for any overspray. This has fixed the issue. 3M 8984 is another product I keep on hand. It's safe on paint and have used it to remove road tar, window sticker residue, etc. Where I did have some Super 77 over spray, I applied the 8984 to clean rag and wiped the over spray off the interior top. Note, I tested it on an inconspicuous spot I deemed it safe to use. Cleaned the light adhesive over spray with no issues. My Bronco sits outside (currently in 98 degree TN heat) and the top liner has not sagged since I fixed it two months ago.
Ford Bronco Soft top separating / splitting / tearing issue!?! (Update. It got even worse!!) Screen Shot 2022-06-15 at 7.26.28 AM
Ford Bronco Soft top separating / splitting / tearing issue!?! (Update. It got even worse!!) 3m-general-purpose-adhesive-cleaner-08984-1-quart-us
