- #16
It's a popular chain I don't want to name, but I'm sure they will honor it at another location.I understand. You could damage the amp if you do not have the resistors so have another shop look for you?
Can you look at your invoice to see if you paid for load resistors?It's a popular chain I don't want to name, but I'm sure they will honor it at another location.
Actually requires 10 so two 20’s are needed. Stacked.Where is the amp @....If you can see it you could look for the load resistors on the high level input. here is a link for pic...AC-LGD - AudioControl
Yours should be the green 20ohm ones
where did you get that info? They don't make 10 ohm onesActually requires 10 so two 20’s are needed. Stacked.
That’s why you use two 20’s. Audio control is coming out with 10’s.where did you get that info? They don't make 10 ohm ones
I spoke to the guy I linked in video and he said the 20's work just fine. no need for 2 stacked. He has done over 30 Bronco installs and no problems. Who told you to stack 2 20's? Audio control?That’s why you use two 20’s. Audio control is coming out with 10’s.
The company I bought my amp from. 5 Star car audio in Clearwater FL. Use what works. I went with Helix instead which adapts to the amp in Bronco base radio. Which is a commonly used type of amp in European OEM radios for years. No load resistors required.I spoke to the guy I linked in video and he said the 20's work just fine. no need for 2 stacked. He has done over 30 Bronco installs and no problems. Who told you to stack 2 20's? Audio control?
Wow. Got me there. I would have guessed grounding issue/noise - but with the car off... There are still a lot of electronics that run, and they make electrical noise, but not much that would be speed dependent. Usually those electronics are pretty well shielded, but who knows.It persists if you turn the car off.
The only other thing I could think to check would be pull the amp out - with it setting out of the truck run it straight from your battery (with just a fuse), and rig up a speaker to hear what it's doing. That's a bit of a pain to set up though. But if it's the amp doing it - that would eliminate everything else.
There are ground loop isolators that you could try as well, they go on the RCA inputs. That's something else cheap you could try
https://www.crutchfield.com/S-lg116fhYCWy/p_127SNI1/PAC-SNI-1.html
