FourHorses
J
Ohio
Fords
Vehicle Showcase
More like this is going to obliterate the Wildtrak in both capability and price.
That's like saying a F-150 Raptor obliterates an F-150 Platinum. Maybe off-road, maybe 0-60 or 1/4 mile, but not in efficiency, comfort, capability as a truck (Towing, payload, etc.) The Platinum wins there. They have their different purposes, they are different tools that have their purpose built capabilities, but you can get either for $60k.
Advertisement
AndrewJ
Andrew
none currently
Exactly, which is why I probably should have specified that I meant desert running capability.
buzpro
Binky
Tacoma
Are you saying the WildTrak will depreciate the fastest and won't be worth much as a trade in a couple years after purchase? Grim!
618TRVLWILD
Ashley
Southern Illinois
Future 2021 Bronco Owner
Love more pictures of...”whatever it is”...I think Mike is a funny man! He cracks me up with those twitter answers! 😂😂 WIS tho looks really good!!
JAGSarge
Moderator
Staff member
Moderator
Joe
TEXAS!
Former Broncos - 76, 93, 95
Vehicle Showcase
Zero_chance
JD
AZ
www.southvalleymustang.com
17 Mustang
Vehicle Showcase
We caught another prototype for the Bronco Warthog (Raptor), revealing new details, including the tire size and what appears to be Raptor-spec Fox Live-Valve Internal Bypass shocks.
Sasquatch-Spec 35” Tires Confirmed
The initial spy shots of the Bronco Warthog (Raptor) weren’t able to confirm the prototype’s exact wheel-and-tire size. These new shots—caught in bright sunlight and sharp focus—can now confirm that the Bronco Warthog is running on the same size set-up found on the Sasquatch-packaged Broncos. The LT315/70R17 tire size is clearly visible on the Bronco Warthog’s BF Goodrich All-Terrain T/A KO2 tires.
Raptor-Spec Fox Live-Valve Shocks Visible In Latest Shots
The 2019 F-150 Raptors saw an upgrade to Fox 3.0 Internal Bypass shocks with Live Valve technology—cuttting-edge units that are identifiable by their bright, metallic orange finish. Our latest front-on spy shots clearly show what appears to be the orange Fox Live Valve shocks peeking out from its black outer sleeve. The high-speed, Raptor-style intent of the new Bronco Warthog was made clear in Ford’s teaser shots of an airborne prototype, and the Raptor-influenced suspension spotted on this prototype further nails down its mechanical makeup.
The rear suspension shows signs of camouflage inside the wheel well, but one of our shots shows another bright, metallic orange-colored component peeking through. It’s impossible to see the exact suspension configuration, but it certainly suggests that the Fox Live Valve technology is in use, front and rear.
Anyone else notice what appear to be high voltage cables?
Zero_chance
JD
AZ
17 Mustang
Vehicle Showcase
Pretty sure those orange "wires" are actually hoses.
Incorrect. You can see a metal terminal style connection in a picture and orange is industry standard for high voltage. Check out any hybrid.
BroncoFanBoy
Brandon
Az
Nissan
Shame they're sticking with the cheesy plastic fender flares and not doing wide Raptor style metal fenders..
I would bet a lot of money that those are placeholders and it will be a wide body like the raptor. Leaving extra extra wide standard flares wouldn’t make sense
colintrax
Georgia
Chevy Colorado, Ford Explorer
Admittedly I'm on my phone and my vision is iffy. However I swear I saw a barbed fitting.
Hybrid was my first thought though.
Stampede.Offroad
SD
junk
I wonder if it will be four door only because that will be more stable at high speed off road.
Even a 116 wheelbase Bronco will be **** at high speed off road. They lengthen the wheelbases of full size pickups to make them stable for race rigs ...
TeocaliMG
Matthew
Dearborn Michigarn
1987 f-250 6.9 idi diesel, 2004 jeep liberty sport
I don't disagree that longer is better for high speed stability, obviously, but trophy trucks run shorter wheelbases than a good chunk of modern full size trucks. Granted many a prerunner are built on those dinky old rangers which were pretty stubby stock... Either way what Philly said is likely true.
Also I don't think anyone expects this to win the Baja 1000, but saying its **** at speed is like saying a Wrangler is **** on the rocks compared to a U4 rig or Rockbouncer.
Also worth note: the F-150 Raptor is specifically not available in the longest F-150 wheelbase. So they are probably still balancing other attributes like weight and breakover vs pure speed machine. Though that point's moot because they wouldn't build a 130" Bronco SUV just for a Rapter variant anyway.
Advertisement
Advertisement
