Springs. I need HD rear springs.
Graham1911
Tommy
Prosper, TX
1995 Ford F150
Is any company making heavy springs I can put on my Badlands SAS without having to replace the struts also. I have added a Zone 3" lift with UCA's. I also added about 150lbs to front and about 200lbs to rear in bumpers, winch, tire carrier, jack, etc. Truck rides squishy. I ordered a set of ARB/Old Man Emu for rear and am having to send them back. Thy will not work on stock Bilsteins. Only on their struts (ARB/Old Man). Eibach is supposedly working on some but won't be released for a few more months is what they told me today. Does anyone know of a company that might have an option?
FleshTuxedo
A
PA
'22 OBX 2dr.
Yes
Graham1911
Tommy
Prosper, TX
1995 Ford F150
Allenm7
Allen
Los Angeles
Ford bronco
I’m looking for same. I don’t think they are any available right now. I was hoping arb ome springs would fit. I spoke to a retailer and they told me that they do on oem? Did you try to install them?
Graham1911
Tommy
Prosper, TX
1995 Ford F150
Please let me know if you find some and I will do same.
broncosor
2022 Bronco Badlands
Same. I posted a thread already on that (same page), also contacted Eibach. They are working on it, no ETA looks like it will be long
Graham1911
Tommy
Prosper, TX
1995 Ford F150
I think I found a solution. I ordered Dobinson. I have them in my garage and will install in a couple of weeks. They come in three colors and I chose black. I called and spoke with a tech at Dobinson and they tested them on the sas Bilsteins and they worked great even though the discription says only on Dobinson struts. Here is the link.
https://exitoffroad.com/product/dobinsons-ford-bronco-rear-coils-c19-569v/
Graham1911
Tommy
Prosper, TX
1995 Ford F150
Yes. They did not work. I think I found a solution. I ordered Dobinson. I have them in my garage and will install in a couple of weeks. They come in three colors and I chose black. I called and spoke with a tech at Dobinson and they tested them on the sas Bilsteins and they worked great even though the description says only on Dobinson struts. Here is the link.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
is there a link to the actual product on the eibach website?
Graham1911
Tommy
Prosper, TX
1995 Ford F150
The Dobinson's have been on my SAS for a few months now and I love them. I have the rear HD springs rated for 150 to 350 lbs. I have 37s, Expedition One bumper with tire carrier, and gear in back. I absolutely love the springs. Great ride without being squishy.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Can you share the exact part # you used? Also, how much lift you got on these with your additional weight?
Dobinson's have several different front and rear springs and notations on what trims they work with are a little confusing. I didn't see springs for BL/WT with +150-350lbs over stock.
Can you also share the approx. inside and outside diameter of the Dobinson springs? The Eibach PRO-LIFT-KIT springs were said to only work with the SAS BILSTEIN PSD dampers, but turned out the fit the Fox's after Eibach tested. They're supposed to be updating their description, and as noted above, releasing an HD rear spring...sometime.
Graham1911
Tommy
Prosper, TX
1995 Ford F150
The spring item number is C19-569V. The fit is perfect on SAS Bilstein's. I got about 2.5" lift with about 150 to 200 lbs. hanging on back. Keep in mind, I have a 3" Zone lift that lifts the front 3" and the rear 2". I removed the Zone rear stuff which is basically just a puck and put new springs on. The front is stock springs with Zone perch, puck, UCA's, with a steel bumper, winch, and bash plate. About 125 lbs. The final result is the rear sits about .25" higher in rear which is perfect. If i add gear or a small tailor it will be level. I have no idea of spring measurements. I just know they work well. The ARB HD springs did not fit. Good Luck.
Here is Dobinson Tech Phone Number. They are great. (305) 424 8353
Here is the link where I purchased the springs. I got black.
