Stealthbox for Bronco
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
The next closest option is $650. I‘ve owned a Stealthbox before, to me it’s worth the cost of entry. I’m hoping it’s in the $830 range of this one for the Jeep and doesn’t include a Bronco tax. They should be able to make mold off the B&O box, so hopefully there isn’t that much engineering it in that increases the cost.
https://www.crutchfield.com/p_13694607/JL-Audio-Stealthbox-Black-Passengers-Side.html
What’s the next closest option you speak of? Got a link?
BroncoAZ
Mitch
BroncoAZ
Mitch
da_jokker
Jeep Wrangler JKUR
I had randomly picked some Ford, and I guess it happened to pick the most expensive one at almost $1,200.
https://www.jlaudio.com/collections...w1-car-audio-stealthbox-ford-expedition-94688
But most of their Ford are around the $800 range, with their mustangs being very close to $1,000.
I doubt by the time you add the Bronco tax this would be a cheap speaker, so some of those other options already out there are looking like a better deal.
BroncoAZ
Mitch
I agree that JL will not be the cheapest option, but I think it will be well engineered. The SRQ with the square sub looks better to me than the audiodesignscq option, and I prefer that they are using a name brand woofer. The laminated layers of MDF wouldn’t hold up if they get wet, a significant concern for a vehicle with a removable roof. I would add a layer of fiberglass resin to the exterior.
derichio02
Bo
Southern California
I can’t find a pic of the SRQ with the stock amp for the B&O system. Also I struck out on trying to find reviews. Wondering if it’s a rattle monster with the L7 in there
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
The one thing that soured the B&O route for me was the reports of all the rattling coming from the enclosure. My assumption is that JL is going to take this into consideration with their design as well. I'm just curious if they're going to build something that will 'hide' underneath the trunk side panels, or if it's going to be a full-scale panel replacement. A full replacement would probably be the best route for minimizing rattling.
MOBRONCO
MO
While Kicker is a mainstream brand, Audiomobile has been around for decades and makes solid products also. I would put the Evo 8 they use in that enclosure up against a JL 8W3 and would give the edge to the Audiomobile with greater XMAX. I think the Kicker may be a bit louder, but the Audiomobile is going to have less distortion and sound a bit more accurate depending on the enclosures.
Slick85
Richard
Austin, TX
So it looks like the Stealthbox will be a single 10TW1... I think I will just get a custom one built because a 4 door SUV needs more than that.
Ford Bronco Stealthbox for Bronco reply
da_jokker
Jeep Wrangler JKUR
I don't know. My Wrangler 4 door has a 6x9 ( or maybe it's a 5x7) sub as part of the Alpine system and the bass is way more than enough for people IN the Jeeps. But if you are looking for the other cars around yours to feel your bass as well, then agreed, you need a larger sub.
BroncoAZ
Mitch
I think a single 10” will be fine for my needs, at least it’s not an 8”. The 10TW1 should be ideal for the application and will work fine with the Kicker Key 500.1 amp I was looking to install. It’s designed for a .35 ft3 enclosure, so about right for what’s available. My main concern is avoiding rattles from mounting behind the panel. Anything is possible with enough foam and sound deadening material.
MOBRONCO
MO
If it’s the one in the cargo tub it’s an 8 by 12, designed to match output of 2 8’s.
BroncoAZ
Mitch
Here’s something to aspire to. RIP Alma Gates.
Ford Bronco Stealthbox for Bronco E813187C-2136-4B31-8455-693610E5126E
MOBRONCO
MO
Alma was fantastic, used to chat with her back in the early 2000’s. I preferred the PPI build of the Bronco though.
