- First Name
- Mike
- Joined
- Feb 9, 2022
- Threads
- 22
- Messages
- 1,185
- Reaction score
- 1,849
- Location
- Russellville, AR
- Vehicle(s)
- 22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
- Your Bronco Model
- Outer Banks
A speaker under the engine??
If I did this and took all those parts out at one time I swear I would have 12 bolts, 10 panel clips and a couple of random pieces left over when I put it all back together.
Still TBD if it helps. Definitely can't hurt. I was pleased to see a decent bit of foam under portions of the rubber floor liner. Pretty thick in some spots, thin in others though.This is above and beyond, looking forward to seeing the finished product!
Also makes me wish Ford just sold an actual sound deadening option for $1,000 or whatever from factory. I'd love some peace and quiet in the bronco, but have no interest in removing the entire interior to do so.
You know... To embarrass my kids at school pick up. And maybe whisper sweet nothings to the drivers who stay in the left lane at all times.A speaker under the engine??
Suggestions?That is a big ass garage bro. congrats! You need more toys imo.
We shall see. It'll be a much easier task to upgrade the speakers in the future. Despite my counter efforts, the bronco will never be an ideal listening environment. The Focals are appealing though.The SI stuff really punches above their pay grads. I'm curious if it's going to be enough for you once done with a project this substantial, or if you, like a few folks I know, end up switching to Focal Utopia (minus the tweets).
You're going a step above with controls, and your install is looking fantastic so far.
This looks great!! I’m glad to see that someone is going the route with a DSP/amplifier that replaces seamlessly with B&O system.The plan has been in the works for a few months, mostly waiting on parts and compatible weather. The weather is here now, but still waiting on a few parts. I'm taking my time and hopefully being careful enough to be able to put it all back together. I'll share some pictures and thoughts throughout the project.
System Components:
There are all sorts of threads and videos out there showing how to remove the guts from the Bronco, so I won't be reinventing the wheel. I will say that anyone endeavoring to go to this length will be glad if they have a variety of panel and trim removal tools and some mega-beefy torx sockets. I have this set for the trim. And this set of torx sockets... a must have when it comes time to remove the seats (and a good length breaker bar). My Dewalt impact wanted nothing to do with the a couple of the bolts.
- Amplifier/DSP: mObridge A2B 8.1.1
- Kick Panel Woofers: Stereo Integrity TM65 mkIV
- Tweeters (L/R dash): Stereo Integrity M25 mkII
- Midrange (L/R dash and center): Stereo Integrity M3 Carbon
- Subwoofer: TBD - waiting on the Stealthbox. We'll see.
- Sound Deadening - a mixture
I'll be running the front L/R stage as active 3-way, with the two higher powered channels of the amp going to the kick panel woofers. Lower power channels to the mids and tweeter. That leaves two of the lower powered channels. One for the center channel... and I'm not sure yet about the rears. I will figure that out along the way. The amp included an additional harness that will leverage the three amp channels in the head unit itself. I will probably use them to power the rear speakers if I don't scrap them altogether.
The midrange for L/R are being cnc milled in order to fit closer with the tweeter and deal with the cramped stock location. That work is in progress this week, then they go to "The Mesh Man" to fabricate the mounting plates for me.
One additional element to this project is the addition of seven sound FX buttons I am adding just below the hero switches. I had seen this Mark Rober video years ago and always wanted to give it a try. I have a separate cheap amp for this, and I've already mounted the PA horn speaker just above the front skid plate.
Here's my status as of today:
I had installed the soundskinz kit along with some additional dynamat I had on the 4 doors a few weeks back. I have some blackhole for the rear and other spots. I have the soundskins kit for under the 4 seats as well. Still need to get the rubber floor liner out before I tack that part.
Here's a peek at the buttons. Not shown is the Adafruit SFX board attached to another ethernet keystone jack. Space was too tight to try to have the buttons and the board in close proximity. This will let me connect the two with a single cable so I can put the board somewhere accessible... for changing out the sounds.
And here's the speaker under the engine.
More to come...
Does it come with all the adapters to use the existing speakers wires including the center and the pods?
I agree, it will be best if it will mount where the B&O sits now so you can use the factory subwoofer enclosure. With a good subwoofer in that enclosure and powered up accordingly it is a good compromise for sure.Good question. It does include a harness to use the 3x head unit channels if needed. Whether you can plug and play all of the speakers is unknown to me at this point. I plan on rewiring since everything is exposed. Some soldering/splicing/crimping is par for the course here I think.
I got a phone call today from Fraser at mObridge. He has his hands on a loaner Bronco now and discovered the harness to use the head unit channels in the Bronco differs from the F150 (assumed to be the same).
He's already ordered a batch and I should have one before I'm zipping things up.
He's also working on an adapter to mount the new amp where the B&O amp used to be. Helpful if one is using the B&O sub. That's not my long term plan, but I may end up with a temporary setup like that until JL gets their act together or I go another route for the sub altogether.
Gotta say, @mObridge / Fraser has shown a level of pre and post sales support that is exemplary. I couldn't be happier at this point, having no experience yet with the actual product.
If Fraser is the company, it shows. And if he's not, where can I get employees like that?
Love me some stereo integrity equipment. I have some sql 15s and the same mid bass, midrange, and tweeters. I’ll be keeping in eye in this built. Why not run a sql 12 in a sealed box for bass? They need minimal space. They are also about to come out with a 11” shallow mount subwoofer too! I believe he just opened the preorder in those yesterday.
Careful now, that's how genocides started!Just as God intended .
I don't know the specs of your underhood speaker but I would mount it higher in the engine compartment and with the horn facing down so that there's no way for it to become a cup/speaker full of water.
