Stock 190mm front axles tough enough to turn 35s?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Sure, you can run 35s on the M190 and not worry as long as you aren't doing anything too strenuous or stupid, but a 7.5 inch ring is just, well, tiny. There is a big difference in strength an inch makes.
I really hope upgrading to the M210 is an option. Axles and CV joints can be replaced with stronger easily enough. Ring and pinion is another matter. I would not do too much hard wheeling on the M190 with 35s, and I certainly wouldn't do it locked.
ChaseH9
Chase
Alabama
N/A
Looks like Ford is offering a factory lift and 35" wheels on the base model. This is important because I want the 7 speed manual.
My question is are the stock 190mm front axles tough enough to turn the 35s? On the SASQ pack I think the front axle is 220mm.
Should there be any concern here?
Front axle on squatch is 210, rear is 220. 210 front is an option on the base model. I'd suggest taking it if equipping 35s. This is why I plan to get the Badlands. 210 fronts come standard and I intend to get the 2" factory lift on 37s
kodiakisland
Arkansas
dgorsett
colorado
F250, Mustang, Explorer
I did a lot of running in snow/ snow-rocks with 4 tire chains did some with an old Jeep with Dana 25 and old Bronco with Dana 30, now in a LJ Rubicon with locked 44' never broke anything, but never had the torque of the new Bronco, so this bothers me a bit. May have to go Sasquatch to get the 210 or resist chaining up the front.
Oliverboots
Frisco, TX
GT350
Disclaimer: I wrote this post bourbon in hand, so take it all with a grain of salt, and if you put 35s on your bronco and your diff blows up, well, it’s not my fault, I’m just some guy on the internet doing math.
Wow! you can think this well and write in such good details with bourbon in blood?! ;) you have to be a cool, smart and steady guy!
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
How much more could the 210 cost? Its an option on every level so unless its over $1,000 I'd say its an easy choice. I'm thinking around $400-500 based on similar upgrades on other Fords
SwankyTiger
2020 WRX
im pretty sure the m190 is the same front as the Ranger so see what they are running
Imissmy1996bronco
2022 JLU Rubicon
WuNgUn
Ontario Canada
2 door Squatched
Do you mean 19mm and 22mm??
Lol
Imissmy1996bronco
2022 JLU Rubicon
Lol
They were referencing the diameter of the ring gear in the differential, not the axle shafts
