Switching out of camera mode in 4WD Low
RatBronco
Morrison, CO
2014 Toyota FJ TTUE, 2009 Dodge Ram 1500
I have the 12" screen LUX package. I noticed that I was not able to switch out of the camera mode when the vehicle was in 4WD Low. This makes it difficult to use navigation without first switching to 4WD high. Is there a way to toggle the cameras on and off while in Low?
TXNavy
Christopher
Spring, TX
GMC Yukon XLT 1500 4x4, Jeep Liberty Limited
There is a camera button on the screen so you can either turn the cameras off or change the cameras between the front, or side mirrors+front, or 360.
RatBronco
RatBronco
Morrison, CO
I must be blind. I can toggle through the different camera angles but I don't see the off/on toggle. Am I missing something?
Ford Bronco Switching out of camera mode in 4WD Low IMG_8639
tobyw
Toby
Washington
2022 4-Door
Bumping this thread back up - any resolution here? Took our first wheeling trip yesterday and was pretty frustrated to loose my NAV when I dropped into low range???
Jer
Jeremy
Oklahoma
2021 Badlands,2017 F350, 2023 F150L, 1976 K20
Had the same issue, push the camera button by the radio and you can turn it off to use your screen for other functions
OffroadBandit
Georgia
Ford F-150
There should be a physical camera button not on the screen. It's not a touch screen button. It's somewhere around the environment controls or radio.
Shoresy
Land cruiser, focus st
Press the physical camera button. I believe it’s top left next to the ASS button. This will toggle cameras off and on.
If you press on the touchscreen with the camera on, a 3-line menu icon appears and you can change the views.
I often mash the camera button, at Low speeds in 2H, when pulling into parking spaces or garage too.
XirallicBolts
Paul
Wisconsin, USA
2016 Flex EcoBoost, 2010 Milan
It'd be nice if certain views weren't locked out by mode. There's times a front tire spotter view would be handy *without* being in 4low
Ditto. I should look into how feasible it'd be to set an Arduino to "if speed is low and front sensors are detecting, send camera request". That or long-press a steering wheel button instead of hitting a camera button. Hell I'd be fine with making one of the Hero buttons do it -- the Front Locker doesn't function in Normal mode anyway, why not have it double as an easier camera button?
tobyw
Toby
Washington
2022 4-Door
Awesome, thanks guys!
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
The button circled in red below toggles camera screen on/off in any mode
Ford Bronco Switching out of camera mode in 4WD Low 1663781309804
