Tailgate opening halfway and then slams back into me
thaddh
Thadd
Kansas City
2022 Bronco Wildtrack and Jeep Wrangler 4xe
When I open my tailgate it goes about halfway and then slams back into me as I step up to get something from the back. Is this normal? I have to pull and then when it bounces back I have to pull a 2nd time to get it to open all the way.
RedDawg
Erik
Chrysler
No, not normal
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
The tailgate has detents that hold 3 positions, 45 ° , 90 ° and 120? ° . If you don't open it fully to one of those positions it tries to close to the the next lowest angle. Sounds like you're opening to 75 ° and it's slamming back to 45 ° .
Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
Is your Wildtrak relatively new? My Sasquatch Badlands did this at first but has since worn in a bit. It no longer has the extreme force but it still tends to swing towards the closed position if it's not locked into one of the indents.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
If you open it, it will assist back to approximately a 45 degree angle. Let the piston settle for about 1 second and then push it again and it will assist back to 90 degrees.
Very simple. I can't believe people have so much trouble with it.
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
Can you clarify "slams"?
It's got a hydraulic/pneumatic (not sure which, both? lol) piston that should prevent it from "slamming" either way (open or closed).
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
You cannot force the door. As described above, it has three detents that the gas piston will go through. Open it, allow it to settle, push from inside lightly and it will go to the second detent, and so on. If you hamfist it, it will push back with equal and opposite force.
thaddh
Thadd
Kansas City
Yes, it's new.
thaddh
Thadd
Kansas City
Good to know.
TX-Hans
If feel like it's not right based on answers here so far, might upload a video of it so folks can understand and provide feedback.
thaddh
Thadd
Kansas City
It may be right. I am used to pulling the gate all the way open without help from a hydraulic assist. Will test that and if it doesn't work upload a vid.
RedDawg
Erik
Chrysler
I just had to check mine after the different comments. Mine opens effortlessly to the 45 angle, stops, then easily opens the rest of the way with a gentle push.
Is that not how everyone else’s works?
thaddh
Thadd
Kansas City
Mine works this way as well after testing. I was used to pulling my Jeep and Defender all the way open without assist. No need to pull all the way on the Bronco.
