Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
@Mitch Panda Motorworks
Will instrument cluster show true boost? or would it be a "lie" because of signal manipulation and whatnot......? (I'm assuming boost is increased.....)
Is throttle pedal signal manipulated? Would one want an pedal booster and this? Is this a pedal booster?
I clicked that one link with tuning details but didnt see the direct methodology used on ecoboost tuning applications......
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Dash can not pick up the unit is installed. This does not change the pedal signal at all.
Sport mode will change the pedal signal if your bronco has that goat mode
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
So boost is increased? and cluster boost reading would be incorrect?
St. Louis
That is correct we are increasing boost safely.
Dash would not read the proper value since it has no communication with the device
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Good questions.
Interested. Can this device be used on another Bronco at a later date? Or is it VIN specific?
St. Louis
Good questions.
It is not tied to the Vin. It can be resold or used on a different 2.3 when ready to move on
redone17
Cold Spring, NY
St. Louis
Awesome. So, any internal testing on Manual at all?
We have not had a manual in yet. We do not see our mapping being any different from the two like other vehicles we have tested and helped with in the past!
redone17
Cold Spring, NY
Spit balling here. I’ve only ever had a tune on a VW TDI and it wasn’t Modular once written.
Is “eco” essentially stock? I ask because I wonder how the tune will effect crawler gear and other off-road needs at slower speeds.
St. Louis
Very similar to stock on map 1 that is correct
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
Honey Badger
