The stupid questions thread
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Which trims come with Molle seat backs? Is this another bug on B&P or does the Wildtrak have Molle seats?
I want to say Black Diamond and Badlands.
brunjc2
Jud
2002 VW GTI
Ask anything you want a one and done answer for, then move on to the next question
Does having the winch affect airflow to the intercooler, or am I just paranoid?
probably it will and probably you are not paranoid this is a really good question. Most OEM ICs heat soak quick. One good hit and it heat soaks, the next hits power reduces considerably. So bigger IC will just make back-to-back hits more consistent. An aftermarket aluminum version would be helpful.
Some newer IC cores are sandwiched with the condenser and radiator. I wonder if the engine controller is smart enough to engage the electric fan if the charge temp is above threshold?
enough of the rant. The OE winch POSITION is junk IMHO I‘ll wait for a more stealth winch (or fab one up) and an aftermarket IC wouldn’t hurt anything.
andi
Why Are the beauty rings on the Sasquatch package Rims silver, if they say warm alloy
Daytona_Bronco
Jay
Daytona FL
2007 Mustang GT
Do the sasquatch wheels have to be removed to take off the beauty ring ?
Marauder
Josh
St Louis
What do you do w/the doors when you remove them off the 2-Door
Clint Callahan
Clint
Tennessee
2013 Toyota Tundra Rock Warrior Edition
I'll throw in my 2 cents on this one. The winch setup Ford is offering will allow for air to pass through the opening in the bumper to the intercooler. It block the front camera though.
Question (I'm sure has been beaten to death): 33" tires, assuming they fit in the wheel well etc, will the stock 4.46 gearing, axles, 2.3L manual tranny, drivetrain, etc, loaded with a rtt and camping gear, handle 33" tires on all terrains?
I don’t know how heavy your camping gear is, but unless mines is lighter than most, roof top tents aren’t crazy heavy. My wife and I tend to do some sort of awkward power clean and hoist it over our heads, then put it on our vehicle. Probably ~150 pounds.
Alright, me next! Bring pretty disappointed that even my cheapest base bronco build is going to land me in the low 40’s, does anyone anticipate that the prices after initial launch will go down after first model year? Had high hopes of a badlands and I’m not even sure about a black diamond anymore. Buy what you really want to enjoy for a long time rather than being unhappy with something that’s not quite what you wanted right?
Daytona_Bronco
Jay
Daytona FL
2007 Mustang GT
Clint Callahan
Clint
Tennessee
Where do we stand on the back pull out tray that was promised? I understand that maybe it was just a concept but I feel like if it was real,
I must have really missed this on
B&P. I want and need that bad. Very disappointed if not. Plan to use my vehicle as a work station
Washbjj88
Justin
South Carolina
Ford Escape
What would it take to add Sasquatch a BL after delivery? I can’t remember the difference between Sasquatch and stock badlands other then the wheels and tires.
BeerForMyHorses
Jared
Nebraska
Ford Bronco 2-Door
Whatever you want. They likely will go in the back somehow, someway, just not as nicely as the four door.
Ford's official stance is only the 4 door doors will fit in the cargo area.
I take that to mean the only way the 2door doors would fit in the bronco is if you fold the rear seats down. The door sizes are bigger than the 4door and won't fit in the cargo area otherwise.
Jpeyer
Joshua
Ohio
2017 F250 Lariat
Wheels tires flares stiffer springs possibly longer shocks and some trimming or larger bump stop to limit travel. (No rub)
