Tie Rods breaking not limited to Broncos
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
BroncoPls!
BroncoPls!
Austin,TX
This why if you go off road, have a spare tie rod no matter what the vehicle is!
PWillette
Parrie
Maine
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
It was never limited to Broncos. They were just the latest to the scene. I have seen this same issue come up with the ZR2 crowd since 2016. One simple solution was adding a sleeve to the inner tie rod and I have wheeled 79k miles without any steering issues whatsoever.
The problem is not knowing how to wheel a front locked IFS vehicle and using it outside of its realistic limitation. It certainly does not beat straight axle but wheeled the right way, these broncos go pretty far.
PCDan
Dan
Park City
1968 Ford Bronco
I was up there the day after. He had to be towed out by the rescue truck that welded the rebar
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Looks like maybe they melted a hole in their outer CV boot too and it’s now leaking. Or perhaps separate issue.. in either case if you have tie rods on your vehicle you should carry spares
