The OEM factory Sasquatch tires have done me well, they survive the EXO Baja run in August without much issue (had to plug one tire) and 2 rock crawling events! I put about 12,000 miles on them. But when I had to use it as my daily driver and go to Oklahoma to check some wildfire burned timber tracts, I ended up with 3 flats! Two happened in one day at the same time (and most likely the exact same rock)! I patched them up and re inflated them to no avail. The patch wouldn't hold so I had to change one tire and re-inflate the other every 15 minutes until I could get it to my tire shop. The tire shop guy said these are cheaply made tires and a hole can easily tear, which is probably why I had 2-3 patches in a hole and they still wouldn't hold air. After he took one of my tires off the wheel he pushed down on it from the top and it basically collapsed the tire 6-8" without effort! These suckers are cheap! Anyway wanted to share with you my experiences and my warning on keeping these tires on your SAS rig. FYI- the OEMs are 6 ply tires and I changed them out to 35" BFG KM3s (10 ply).
