The red circle. So the diode is part of the package. Thanks! Looks like it's a snubbing diode included in the package to subdue inductive kick incase it's driving an inductive load like a relay or solenoid.
Do you have a picture of the G connected to the circuit board? Did you solder the wire to the circuit board?I can't tell if you're trolling or are confused...
Inside the red box is the transistor. There are no additional diodes... Inside the green box is the rear dome light circuit board. I did make a mistake in my previous post, but it doesn't affect how you connect it. I dont think the diodes on the circuit board are not LEDs, else the symbol would have a couple arrows coming out to indicate light emitting. Those must be the diodes on the circuit board prior to the LED.
Anyway- just connect a lead where the purple line is on the circuit board to the G on the transistor. Yellow wire in harness to S and run D to the new LED lights. Pretty easy tbh.
Sure, hereDo you have a picture of the G connected to the circuit board? Did you solder the wire to the circuit board?
Awesome! Thank you!Sure, here
No, you can’tAlternatively, could you remove one of the surface mounted LED's and solder a pigtail to the positive and negative and run lights from it ? I want to try it but don't want to sacrifice my light.
No, but this one is the same as IRFP 9140 https://www.amazon.com/gp/product/B0854HJ43H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1I think I understand, this looks pretty straight forward. But is this the correct transistor? It says ON
https://www.ebay.com/itm/2938566328...LWMTvs1Q56&var=&widget_ver=artemis&media=COPY
Will this one work? I have a Walmart order to place and this will get me to free shipping lol.No, but this one is the same as IRFP 9140 https://www.amazon.com/gp/product/B0854HJ43H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
No, this is a N-channel, will burn circuit! You guys better be careful …to not catch a fire! Use the same model as I mentioned aboveWill this one work? I have a Walmart order to place and this will get me to free shipping lol.
https://www.walmart.com/ip/10pcs-IR...0-Power-MOSFET-TO-220/2830458727?from=/search
Thank you, I have a basic, understanding of circuits and soldering, but not when it comes to something this technical. The Walmart order no longer matters because I found out today that I got drunk the other day and ordered a DVD of ski patrol off eBay and that was making up my Walmart order for free shipping LolNo, this is a N-channel, will burn circuit! You guys better be careful …to not catch a fire! Use the same model as I mentioned above
