- Vahe
- Nov 4, 2022
- 9
- 58
- 105
- California
- 2022 Ford Bronco
- Wildtrak
Hello friends, I know how terrible the Bronco's interior lightning is, and this is not the first thread about it. So I got Lights from @IAG Performance , but I didn't like the way how they operated, so by their instructions you need to connect them to the door opening "sensor" wire and if you want you can hook them up to up-fitters. I found a way to make them work in conjunction with OEM lights Since we can't just attach those additional lights to the OEM lights by parallel connection. But we can use OEM lights as a signal to turn on the additional lights in a synchrony way. Initially I was thinking about relaying with a LDR sensor activation, but found an easy and much much less power consumption way by using a Transistor IRFP 9140, this is a P-Channel transistor. I will attach below the simpliest scheme to connect it to the back Dome light.
