Upsized Tires and MPG Drop
BostonGuy
Boston
Jetta
Comment and Question.
I've got the 4dr non-sas OBX, went from stock tires to 275/70/18 General Grabber ATX. My MPG dropped by almost 2 (1.8). 10% seemed like a big drop.
In a perfect world do I need to use forescan or have my dealer "update" to car so it knows the tires are bigger? I'm assuming the bigger tires have better MPG then the computer is guessing.
HBTFD
Newnan GA
F350
If the tires have a larger circumference you are correct.
ProdigyJKU
2012 Wrangler
Part of it is that you speedometer is off. So now it thinks you only traveled 200 miles, when you've actually traveled 210 miles, throwing off the mpg calculations.
Other part it that the heavier tire mass and higher vehicle height making ot less aerodynamics.
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Seems like a big drop regardless. I don't your engine size or gearing but there is a reason different packages get different gearing set-ups.
I've done similar on other vehicles and not seen that big a drop off on the computer or IRL when measuring via gps and at the pump. I'd be curious if you note a decently long trips mileage with google or something and manually calculate mileage at the fuel pump.
BostonGuy
Boston
Jetta
I'm 2.3 with the standard gearing 3.73(?) I think. I'm mostly a mall crawler
Drex
Jake
3.4% is error from larger diameter tire. The rest is added rolling resistance, air resistance from the wider tire, and a touch of weight increase. Actually it seems to me that you did better than I would have expected.
pakrat
JG
Lake Tahoe
For perspective, I just finished a 1500 mile road trip. Sasquatch/2.7/4.7 gearing. 18.9 MPG on board computer, and 19.1 when I calculated it myself. 80-90% highway miles at speeds of 75-85 mph mostly. It stayed at an easy 1800-2200 rpms at those speeds and going up many mountain passes at altitude. The sasquatch gearing is perfect for 35" tires.
I'd run a manual calculation next time to go somewhere of any distance and keep track of those miles via google maps. I'm betting you don't suffer as much as you thought depending on your driving style.
If you don't think it feels like you lack power or the mileage isn't too much worse then have it calibrated and keep loving your Bronco. If you don't like the performance or the mileage has gone to crap because it has to select lower gears to keep up speed than you might think about re-gearing. I know that sucks but if you plan to have it for a long time and keep larger tires on it or even go bigger than you'll be glad you re-geared sooner than later. Better mileage and less stress on the drivetrain for the life of your Bronco. But do the manual fuel calcs first and ask yourself how it performs first and foremost.
