following
Still working on a bit more before a write up. with what I ordered drivers side was plug and play passenger side I had to change the connector. The forscan to turn things on. Still have not sure if ford has a light with the proper connector without having to swap for the passenger side. Not sure if the stock lights were this way but the passenger side seems dimmer than the drivers side. I ordered these they are identical in size to stock. I have to say they are not as bright or colorful as the aftermarket setups. But also very clean install and controls in the settings screen. Now a guy I’ve been working with to figure out cup holder ambient lighting has said the ‘22 F150’s the forscan is not letting them fully enable the color change. So for the ‘22’s this may not work.Very nice. So looks like it can work...at least so far. Simple plug-n-play on the lights? Can you share part numbers needed and possible sources?
yes for drivers side under dash plug and play. Passenger side the part I ordered which is listed in the post came with the wrong connector but I just swapped out the connector between the two lights. I unsoldered it from one led circuit board to the other. A guy could easily cut and but connect the wires back together. The cup holder well that’s just a mock up in the pictures and I have a lot of work to do to make it look good. That part is definitely not plug and play. Lots of trimming the console and new cup holder had to be done. Wiring harness I found a guy in a other forum but could easily be done if a guy could find the connector part numbers for a LOT less $$. Waiting on parts to finish the under seat lighting.You really need to make a detailed guide
but so far, order the f150 pieces for the footwell?
how plug and play is it, ill have to find a forscan guide later
Forscan is worth downloading and activating. I’ve only done the free two month version. I hear guys having problems buying licenses as they are based out of Russia. It’s basically a forum site. I hope it doesn’t go away completely as it really is a useful tool. It’s worth it just to get rid of the double honk and ignition on chimes.Just need to find someone in Jersey or nyc who can FORScan it for me at that point, Id provide the parts
oh I know, just didnt realize it was still aroundForscan is worth downloading and activating. I’ve only done the free two month version. I hear guys having problems buying licenses as they are based out of Russia. It’s basically a forum site. I hope it doesn’t go away completely as it really is a useful tool. It’s worth it just to get rid of the double honk and ignition on chimes.
I’m trying to get a good write up going the weather is not cooperating for me to get some good pictures. And trying to type a big thing up on the phone is for the birds lol. Everything has been in and working well. I haven’t forgot about it.Very cool stuff! Can’t wait to see the final write up. Thank you for this!
