Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Hey guys, question for you that have installed this. I'm going to attempt this setup on my Everglades but was wondering what people have done to mount it under the rear driver and passenger seat? Zip ties or a mount that's more sturdy. Thanks!
My 4dr badlands had mount’s already there. The lights just clipped in.
Bigmoose
Jon
RI
Sorry I misread your post. I thought you meant under the driver and passenger seat, not the rear seats.
Egg16
Everglades
US
Everglades
Attached some pictures from under the driver seat.
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_3080.JPG
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_3081.JPG
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_3082.JPG
Mad Martigan
Matt
Oklahoma
Fords and 1 Wrangler
Egg16
Everglades
US
Everglades
i911fire
Ryan
Kansas
2023 Code Orange BRaptor
Just a thought for you guys that have the manual Broncos. I was looking at mustangs today and noticed that the cup holders in a 2019 Mustang. They may work.
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_0752
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_0753
Stevdug
Tulsa
2022 base bronco
Ford Bronco Color changing ambient lighting using Ford OEM parts 1000005441
Got most everything done today in my 22 raptor, still have to mount lights under the seats. I did have to file off the light harness connector under the driver footwell, but all went pretty well. I've missed the color changing feature ever since I sold my 2017 raptor
JHForman812
Floyds Knobs
2022 Super Duty
lol glad the harness got to you the second time out!!
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
TLO
E
Canada
youtube.com
2 door Squatched
Edit this is my experience for my vehicle I cannot guarantee results for your vehicle proceed at your own risk!
Ok first attempt at trying this so I hope you can follow along.
I set out to put the color change ambient lighting in my bronco but did not want an aftermarket setup(yes aftermarket would have cheaper by far)
so I started in forscan in the plain English apim. By changing the ambient lighting type to pantatone and write that gets you the color selection screen
I also found a thread on an f150 thread that said to change a line in the as built apim as just changing the plain English does not let you actually use the options on the color change screen.
That seemed to do the trick so I then ordered some led’s from ford. Here is the list I found and what I ordered.
After a month the first two lights showed up. The drivers side was a simple swap with just having to shave off two guide nubs so it would plug in.
The passenger side factory light has a female end vs the male. I did not get pictures but I swapped the ends so I could plug it in. In the parts list the passenger footwell light may have the correct end but I ordered these particular lights because thewere the identical size/shape for our factory holders.
Once this all worked one of my sons asked are you going to put them back here for us in the back seat too. Well then I looked under the seats.
I’ll be darned if ford didn’t put a rectangle hole the size of the ambient lights built into the plastic under the seat.
I then remembered a post on the ford truck enthusiast forum of a member making and selling ambient light harnesses for the superduty and offering cup holder setups as well. I got in touch with @JHForman812 to make me a harness for the lights under the seats and the cup holders.
After much discussion and measurements he found a cup holder assy that he thought would work.
This part of the project is not for the faint of heart. The cup holder is not a drop in replacement. Many things had to be trimmed on both the underside of the console and on the new cup holder. All 6 mounting posts on the console had to be shortened by 1/4” or more but it was a slow trim test process. I did not get get pics of my cutting the console up. It was tedious to get it to look good. Maybe an hour and a half of work. The cup holder comes with everything except the led’s. The harness guy supplied them as well so I do not have part numbers for the leds themselves. After I received everything it was just a matter of plugging the harness into to where the drivers side light is connected. This harnes extends out from the driver side ambient light connection. Then removing the console and running the wire extensions from the drivers side ambient light under the dash thru the console and then down under the seats. The under seat leds will fit in the rectangle holes without any trimming and if you press firmly will stay. If you want a completely flush fit under the seats minor trimming is needed to the seat plastic. Then you have ambient lights that change color in five locations.
because I added the under seat lights and cupholder lights I’m in this project for near $300. I ended up ordering two seats of the under seat lights. I don’t see a difference from left to right so a guy could order 4 of one and be okay. But it’s all factory led controlled through sync and looks factory. If a guy got the connectors and made his own harness he could probably trim costs down quite a bit.
Edit I forgot a couple pics drivers side led and connector
passenger side
My 2015 Fiesta is loaded with these multi-coloured LED's.
Time to go scavenge! 🤔
Ant0ni0S
Antonio
2022 Ford Bronco Wildtrak
I did do this to my bronco and it turned out very well. Still can take the doors off because the wire disconnects where the bolt for the doors are.
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_2010
Ford Bronco Color changing ambient lighting using Ford OEM parts IMG_2011
HeHateMe
San Antonio, TX
