What rims and tires you going with?
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
Go small and stay home! (y)
Hey, those are 265/75R-16 AT tires I added. They handle the speed humps at the local Fred Meyer just fine, thank you. 🤪
Broncodave
Seattle
I was not disparaging them. I love them!
NurseDan
Dan
Lethbridge, Alberta
2017 Focus
For me personally... looking at the tried and true BFGoodwich KO2. Which luckily come standard on the Badlands non-Sas.
Longer term I may try these Nitto tires that everyone seems to love. But 3PMSF rated tires are important where I live, and I'm not sure if any of the Nitto tires have that rating.
Happen to have a link or model number for those steelies?
I have the Badlands with the beadlock-capable wheels on order, and I actually plan to install beadlock rings on them. To avoid having to remount tires all the time, hoping to grab a set of steelies I can use for everyday driving.
A lot of the hybrid tires are designed to do that, the Ridge Grapplers being one of them. You air them up to normal pressure 35-40 PSI and it sits largely on the center tread to behave more like All-Terrains. Air them down and they behave more like Mud-Terrains.
If you look at unmounted Ridge Grapplers from a side profile point of view, the center tread looks like it is 3-5mm higher than it "should" be. Milestar Patagonia has a similar setup on their tire. Kind of an interesting design, but truthfully not sure how I feel about it.
Bought through partsengine.ca. YKWWheels is the distributor and I believe they are manufactured by DTDWheels out of Quebec. Model # is YKW203. Under $84CAD a piece.
https://www.partsengine.ca/search.aspx?SearchTerm=Ykw203#SearchTerm=Ykw203
Now, fair warning: all the specs match up and they even have a little ford badge stamped in them. I only ordered my Big Bend last week (have a July 14, 2020 reso). Won’t be able to confirm they fit for a good long while.
RagnarKon
Ford Bronco, Escape, Focus
Thanks!!
Only shipping in Canada… mmmm…. I live 2 hours away from the Canadian border so I could probably make it happen, but not sure if I’d make it back across the border through customs 😉
Was having a super hard time finding steelies with the correct bolt pattern and yet still had an offset that would keep the tire under the fender. But those you found look to be perfect.
Lifeliberty
Moonbeam👀
Columbus, OH
Stock SAS wheels n tires until something breaks or wears out, then see what's available.
If it aint broke don't fix it, but if it breaks then upgrade and it feels like a new vehical
darkscion0
Canada
2016 Mini Cooper
Stock Sasquatch wheels and just ordered a set of 35x12.5 Nitto Mud Grapplers yesterday.
May go beadlock on the stock wheels once there are cheaper 3rd party beadlock rings available.
NurseDan
Dan
Lethbridge, Alberta
2017 Focus
Thanks!!
At least the Alberta news has said they just opened the border to travel. If the price is right, may be worth a phone call to border station and a road trip :)
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Brock9281
Atlanta
What’s the going rate for resell on 5 Sas wheels?
Bscholl8
B
Austin
2021 Oxford White Bronco
I added 33s to the stock wheels and a leveling kit. A lot of people like the ‘old school’ look with the steelies.
SnowBronco
Canada
I went with these.... But I may powder coat them over winter. Fuel Shok, 17x9. 1 offset. With Toyo Open Country CT 33's.
Ford Bronco What rims and tires you going with? PSX_20211031_165546
tedweb
Ted
Georgia
Mazda, KIA
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
AlexInNY
Alex
Shelter Island
BMW 428; Grand Wagoneer; MB 230E; Pacifica
Went with these: 17x8/0 offset/American Racing AR172s wrapped in BFG KO2s at 295/70/R17. Rubbed a little going forward, but a good bit in reverse at 60% lock. Removed crash bars and now it fits perfectly.
Possible for you to show the poke on these? Love the look and being able to buy a mounted package at Tire Rack makes them an easy purchase. Not sure how the -12mm offset and back spacing mix works out.
