Who do you use to mount + balance tires?
hammer_head
Troy, MI
Explorer Sport
So I normally buy tires from tire shops that also mount, balance etc, but today isn't a normal day. I have some tires on order that are being delivered to me and as such I am now in the position of taking my Bronco somewhere to get these bad boys put on. I was wondering where people usually go to get something like this done. I can definitely call up some shops, and most likely will, but given that this may be a special task of upgrading from 35" to KM3 37" tires I want to be sure I am going about it right the first time. Also, anything else I need to consider? Speedometer adjustment etc.?
Back story, I have a 3" BDS/Zone lift, 1.5" wheel spacers, and JKS Max Tire Clearance Kit + Heavy Duty Tirerod Sleeves so I am set up for the 37's.
Also, may or may not help but i am in Oakland County Michigan area (Troy).
Thanks, Bronco Fam!
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
To mount/balance tires I use my dealer. They have a full-service diesel shop and are one of the few places local to me that have a tire balancing machine that supports larger tires. The only thing my dealer WON'T do for me is mount beadlocks (liability reasons), so I usually struggle-bus my way through that in my driveway.
I would imagine most 4x4 shops can mount/balance larger tires.
For speedometer changes, I do that myself with FDRS and/or Forscan.
hammer_head
hammer_head
Troy, MI
Explorer Sport
Yeah, I think that’s my issue… I called the dealership near me and once I said 37’s it was a no. I’ll have to call the dealer i bought from to see if they can install.
Oh and thanks on the Forscan tip, I thoughtI read somewhere that you had to adjust for larger tires.
Bschurr
NY
I would also HIGHLY recommend road force balancing for 37
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Mostly, someone who understands what the red and yellow dots are for on the tire.
Donkeygyrl
Sheri
San Francisco
Bronco on order
I had some e rated 35 mud tires (heavy) installed by my tire guys they used the beads inside the tire,no weights and always stays balanced.
Fortydegnorth
Kettering Ohio
2022 Big Bend 4dr, 2023 Big Bend 2dr
I mounted my 35’s myself to save me from hauling a stack of wheels and tires. Once I had them on the Bronco, I drove it to a tire shop near me, less than 2 miles and they balanced and aligned everything. Mounting large tires with spoons/irons is easy and saves hauling a trailer load to the tire shop If you ordered tires online.
