Will cargo security drawer allow for a fridge/freezer slider on top?
broncomorrow
Indiana
2021 Ford Bronco First Edition
Anyone know if the cargo security drawer will support installation of a slide for a fridge/freezer on top? I'm sure it will support the weight on top, but unsure about the load once the slide is extended out.
Ford Bronco Will cargo security drawer allow for a fridge/freezer slider on top? vm2dz-78115a00-e
Tdifonzo
Thomas
Audi S3
This just gave me an idea. Someone needs to build a pull out fridge/freezer in this form factory.
Theherofails
Thomas
Phoenix
Probably.. with the MIC top. You won't be pulling anything out the bed with the soft top on and that drawer system in place unless you take the rear window out every time. The kickstand just doesn't open it up much. an extra 12" or so over the tailgate. As far as mounting it to the drawer system, that part should be fairly easy.
Maybe there is an easier way to open the rear window on the soft top, but it didnt seem that way when I checked out the preproduction vehicles.
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
Check out this around the 8 minute mark.
broncomorrow
broncomorrow
Indiana
Ford Bronco Will cargo security drawer allow for a fridge/freezer slider on top? 1621631516470
Not the exact same, but should provide a sense of scale/dimensions.
Thatā€™s what Iā€™m going for, itā€™s just unclear how well the drawer box is secured to the floor of the cargo spaceā€¦if I slide 100+ LB fridge out will the whole thing want to tip out? Not sure if it is designed for this type of application or not.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Excellent question.
Iā€˜ve been very interested in the security drawer options, and havenā€™t seen anything on how it mounts yet.
It would have to mount in a way that is secure enough to support the drawer being extended outā€¦ so with the drawer and contents inside, It would probably be able to support the weight of a fridge extended outā€¦
ā€¦but youā€™re smart to check first.
da_jokker
Jeep Wrangler JKUR
Total guess, but it's smaller brother, the slide out tailgate was designed to allow you to stand on it to reach the roof. Guessing this mounts the same way so I wouldn't think it would flip up on you.
Now whether it's rail hardware is quality enough to dangle out with that much weight..that's an unknown.
BroncoKong Jr.
Andrew
Excellent question.
Theoretically it mounts to the four tie-down points, either directly to them, or by unscrewing them and using the thread (or some similar method).
