Looking to pick up a set of Badlands take offs. Anyone know if 5 will fit in the back of the outer banks with the seats down?
You can make use of the spare as well if you’re in a pinch. Take off the OEM wheel at home and replace it with the BL at pickup.I brought 5 home with seats down and some moving blankets to protect interior. Tight but it can be done
Awesome! Thanks for the pics too. I feel much better after seeing this set up. Much appreciated.I have a 4 door with soft top. I bought 5 take off tires from SAS owner. He helped me as he had done this with new tires also. I had a passenger in my front seat. 2 tires laid flat on top of the back seats folded down and 3 in the back standing up parallel to the ones on the road. Good luck
Maybe this explains the 37" spare K02 on a SAS I saw with otherwise stock tires on the way to work todayYou can make use of the spare as well if you’re in a pinch. Take off the OEM wheel at home and replace it with the BL at pickup.
Yes, if you use the spare rack for one of the 5. In other words, remove your spare before you leave home, thats what I do. 4 inside, 1 outside on the way home.Looking to pick up a set of Badlands take offs. Anyone know if 5 will fit in the back of the outer banks with the seats down?
