I just purchased a used 2022 base Bronco and it has a ton of wind noise. I wasn’t expecting it to be quiet but it’s pretty loud. Is this normal? Anything I can do to make it more quiet?
Have you ever driven this type of vehicle before? When you say loud what’s your comparison? That’ll tell you if if you or your Bronco.I just purchased a used 2022 base Bronco and it has a tone of wind noise. I wasn’t expecting it to be quiet but it’s pretty loud. Is this normal? Anything I can do to make it more quiet?
We really need to stop pushing this whole "it has a removable top so it's okay for it to sound like a window is always open" thing. No one enjoys the wind noise and Ford definitely could've done a better job with that.Have you ever driven this type of vehicle before? When you say loud what’s your comparison? That’ll tell you if if you or your Bronco.
Don't assume I'm giving OP a hard time. I came from a sedan and it was a huge adjustment on the highway.We really need to stop pushing this whole "it has a removable top so it's okay for it to sound like a window is always open" thing. No one enjoys the wind noise and Ford definitely could've done a better job with that.
Anyway, yes OP it's a loud car. There are some guides on the forums where people put foam/rubber stripping on the hard top's seams to make it a bit quieter if you want to try that.
after numerous jeeps and such i expected noiseI just purchased a used 2022 base Bronco and it has a tone of wind noise. I wasn’t expecting it to be quiet but it’s pretty loud. Is this normal? Anything I can do to make it more quiet?
yah I knew the bronco wasn’t going to be a quiet car & I drove one on the freeway before purchasing it, but the wind noise is definitely there. a lot of ppl here will tell you to stop complaining, but if you can make it a bit more quiet, then why not?I just purchased a used 2022 base Bronco and it has a tone of wind noise. I wasn’t expecting it to be quiet but it’s pretty loud. Is this normal? Anything I can do to make it more quiet?
