j_anderson
Jason
Fort Wayne, IN
www.instagram.com
my issue is it’s coverage area. I have an iPhone 13 pro (so not a SMALL phone by any means, only thing bigger is the Pro Max) but after a few minutes of regular driving or turns, the phone moves a little bit and breaks it’s wireless charging connectivity. What a poor charger.
This is why you need MagSafe compatible charger and why Ford should implement MagSafe and Fast Charging. With MagSafe, your phone will align to the charger and stay in place for optimal charge. If you can go one farther and add a fast charging power adapter, you'd get a higher power charge to better keep up with wireless CarPlay
https://www.amazon.com/HATALKIN-Mag...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
bwomp91
Brad
2019 Ranger
Well, if anyone dabbles in REMOVING the garbage wireless charger from the Lux package, please share. I don’t have the space beneath to tuck an aftermarket one because it’s taken up by the factory one. Would be interested in a swap.
TommyBronco
Thomas
Toms River NJ
Ford Bronco Wireless charging pad DIY install hack 9E4C5A37-A227-4951-B102-D0CA683F5CFD
Ford Bronco Wireless charging pad DIY install hack F7C2FBB1-D787-41A0-AF64-9763B1949CE7
Doesn’t work with mine. But I’m sure I can fine something I can 3M in Place behind the shifter.
Rosanna
Rosanna
Blkdiamond
New York
FJ Cruiser
Mrpenn46
Nebraska
Badlands - Cactus Gray
Wonder how long until people do write ups on putting in the factory wireless charger. Should bolt right in (there’s a blank cover plate in place on vehicles not equipped) just would take some wiring knowledge.
There is a pretty good chance the connector is already on the harness, it might only take buying the kit and finding the connector to plug it in.
TommyBronco
Thomas
Toms River NJ
Scosche made a universal kit to add wireless charging to cars, came with a bezel plate. I wonder if it would be easy enough to get it to drop in just right in that block off plate seen in the second picture. Better than spending $320 for buying the OEM one and then having to pin out the power for it.
Great idea. Looks like I may need to cut it to fit. Do you know if that block off plate is removable? Looks to be exactly the same as the auto transmission configuration. Has anyone taken that off?
Rosanna
Rosanna
Blkdiamond
New York
FJ Cruiser
So I did another mod today put silver vinyl over bronco letters in grill. It’s not perfect but not bad either.
Ford Bronco Wireless charging pad DIY install hack 0E81EEF1-2040-4F95-9F10-2B5B846B772C
after
Ford Bronco Wireless charging pad DIY install hack 955AFB3A-481F-4B08-A573-CA75E9F30AE1
Before
MacDonald_Photo
Jamie
Eaton Rapids, Michigan
2021 Badlands
Is this the one?
https://amzn.to/3F6wNMv
Ford Bronco Wireless charging pad DIY install hack Screen Shot 2021-09-29 at 16.58.23 PM
Can someone measure the dimensions in their Bronco to see if this would fit decently?Dimensions are: 2.24 x 4 x 8.63 inches
TommyBronco
Thomas
Toms River NJ
Rus-T
Rusty
FL
Ford Bronco Black Diamond
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
I really like this. I prefer something more permanent then plugging in a charger. Did you need to disassemble the front console or just pop off that access panel? I'm looking at your wiring, but I don't see it....how did you wire it in?
