Zone 3” Adventure Series Lift Kit, Pro's and Cons?
JGB1966
Justin
San Antonio, Texas
2022 Big Bend Sasquatch 2.7 Auto
Am looking for some input, after the latest trip to Colorado, I'm in the market for a good 3" or adjustable lift in the 3-4" range.
I'm curious as to thoughts on the Zone #" lift with upper control arms.
I may or may not go to 37" tires. If I do it will probably be a few years
Currently have a 22' Big Bend, Sasquatch, 4 door. Love the way it performs on the trails and rides on the street, just looking for a little more clearance. and a better stance on the 35's
Thank you for your input.
Mamma's daily driver, but I get to build it for the trail.
Frankie945
Frank
Louisville KY
Q50
I would also look into lift springs like eibach or Dobson because they keep you within the limit of the oem suspension geometry. But if you wanted that particular zone lift I think it’s okay too. I wheel with a guy on 37s with that lift all the time and he really likes it and has had zero issues whatsoever with it or any other driveline component.
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
As long as you don’t have a lot of weight in the back, it works pretty good. We had it on ours for a year until we upgraded to RadFlo coilovers. They worked great on the trails and at the sand dunes. Enough clearance for 37s as well.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Here’s mine. That kits been installed for nearly a year now, zero complaints. Still rides very nice too, which surprised me. On 37” KM3s.
Ford Bronco Zone 3” Adventure Series Lift Kit, Pro's and Cons? IMG_8552
did you have any clearance issues with the 37”?
j_marinelli
Spring Branch, TX.
I've had this kit on mine for about 16 months and it has been good. Like @HeliPilot , I'm also running 37 km3 though mine is with a zero offset aftermarket wheel. I have had mine rub in the front on a full turn backing up once but other than that, it has been good. Only complaints is the KM3s have gotten a little noisy as I have racked up the miles on them (think I have put close to 20k on them).
I will note that I think about a month after I installed these that Eibach came out with the their stage 2 coilover kit. If it was available when I pulled the trigger, I would of spent a little more and gone that route.
picture for reference:
Ford Bronco Zone 3” Adventure Series Lift Kit, Pro's and Cons? Screenshot 2023-07-17 140027
HeliPilot
Kenny
CT
2022 2.7L SAS
Wouldn’t know because I installed the JKS Max Tire Kit at the same time. And I run spacers on the factory wheels. So I’ve never had any clearance issues.
Twister22
michael
lone jack,mo
2012 Raptor 1965 Mustang 1968 Mustang
I went with the 3 inch Readylift for the Sasquatch package because it has the rear track bar bracket also in the kit, running black rhino wheels, Yokohama 37’s
Ford Bronco Zone 3” Adventure Series Lift Kit, Pro's and Cons? 86DAA0BB-DDA0-4B3A-B968-8E9D1E59128A
Lak34ers
Troy
Seattle
Went with Bilstein 6100s which are 2.5 and adjustable. Added about 2 inches and leveled it. Super happy with it and drives a lot better than OEM SAS. Jeepandtruckparts has the fronts for around $210 each which is a smokin deal. Just another option for around $1000 for all 4 and doesn't hurt geometry and improves ride and a 2.5 shock.
Oldhippie
Barry
Santa Cruz, Calif.
I only have about 500 road miles on mine but am happy so far (added rockjock track bar bracket with kit)…will see when I hit some rocks in a couple weeks…would like to see someone offer a 1” diff drop…
raptorbill
bill
STERLING HEIGHTS, MI
2020 GMC Sierra AT4
I’ve had the zone kit on for 8 months now and had zero issues. 7 thousand miles.
Also have wheeled it a fair bit. Nothing major. Mostly 2 tracks in northern Michigan.
37KO2's
Ford Bronco Zone 3” Adventure Series Lift Kit, Pro's and Cons? bronco 1
Caleb@PandaMotorworks
Caleb
St Louis MO
Eibach coilovers FTW! We seriously cannot recommend this setup enough. By far the best bang for buck lift kit on the market currently. They offer a great ride and they are extremely durable! Also height adjustable so you can really dial in the right to your preference!
Eibach Coilovers - Ford Bronco
We have these available right now for a STEAL at $1500 with free shipping. I would be happy to get you set up or answer any other questions you may have!
bjpatten
Apple Valley Utah
2022 Bronco
Did you do anything for the gears besides putting on the lift and 37's? I have a 3 1/2" lift and want to go with 37's but not sure what else I need to do.
HeliPilot
Kenny
CT
2022 2.7L SAS
Nope, but I do have the ford performance tune. Mostly to correct the Speedo, but the power bump help with the tire size.
