¡ Bronco Will Not Get A Disconnecting Sway Bar !
Status
Not open for further replies.
jjmtuttle
Jeffrey
Usa
Good to know looking forward. One had to know with Lovell involved he had to put the bug in their ear about how is has to perform. don't want it to be a laughing stock. Thanks jjmtuttle.
Ford put a lot into this and it has been pushed back a couple of times but the technology put into this is unreal.... Can't wait
Not a T6 then, or is the next gen that modular?
Having different frame rail widths would be very unusual. One ton trucks with chassis cabs or beds is the only place I think I've seen that. Seems like the kind of thing that ought to come with a set of solid axles.
SMH here we go again
JimmyDean
Louisiana
No v8, optional 7 speed manual trans 1st gear is creeper, up to 37" tires, warthog addition for the climber's also sits on wider frame. Ranger will have a face lift for 2021 to set with the bronco look... in my opinion Looks like they trying to fit something for everyone the soccer mom's, The Rock crawler's and the daily driver cruiser... Can't wait I'm in line to match with my 1996 Sport Bronco
that would be...unique. Would the wider frame be using same body/same overall width, or are we talking significantly wider overall width with this? TBF that would be intriguing
BAUS67
redneck
Central PA
I thought they would just do like always and just upgrade the platform, not make a whole new one.( I say platform but insert frame) for the "warthog" as it seems I have read it be termed. Just changing pick up points would be easy. But that is good news !!!! By putting in that kind of effort I'm sure it will be awesome !! :thumbsup:
BAUS67
redneck
Central PA
I wonder if this is the body Joe saw ……… it would explain the bigger size ?????
jjmtuttle
Jeffrey
Usa
Nothing to say to you....
jjmtuttle
Jeffrey
Usa
All Bronco frames will be the same the ranger will not be as wide..
BAUS67
redneck
Central PA
Oh got 'ya thanks for the clarification.:like: makes more sense.
CJay
Chad
WI
'08 Ranger FX4 (MANUAL) & '74 VW Thing
Wow this thread is a trainwreck! There's something for everyone. SFA, IFS, TTB, trail welding IFS, no/yes/no disconnect swaybars, and more trolls then a collection of Grimm's Fairy Tales.
I just want to know how well it will compete with the incredible Jeep!
Guess I'll just have a wait a few more weeks.
BAUS67
redneck
Central PA
LOL CJay !! and makes my point "my Jeep can do that", it looked like the first time he ever tried to climb something, typical got scared and didn't know what to do so he hit the gas. It looked to me like it would have rocked back and he could have just backed off then. ……. I thought it looked a little tall for a stock Rubi TJ before I started the video. I can't wait either this is gonna be epic !!!!! :please:
edit: forgot to mention also makes the point about approach/departure angles and lockers you can climb a tree.
OX1
jackson nj
59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
Estimate 28" under that tire and all 4 still on the ground. Do we expect the new IFS to come close to this?
For reference, a longer WB, built about as far as you can go I'd guess. I'm guessing 36" (think it was a 38 tire)
CJay
Chad
WI
I think you missed the point of the post... 1) I was backing up BAUS67's point and 2) trying to lighten up the mood.
YMMV Based on the amount of money you throw into the vehicle...ether from the factory or aftermarket.
I believe you can find YouTube video's of H1's scaling a wall.
Ford Bronco ¡ Bronco Will Not Get A Disconnecting Sway Bar ! 1582472080556
dmtndan
1991 Silverado, 2014 Malibu
I feel like we forgot about the chairs for a while... didn’t read everything but I feel like they should be tossed in here just in case. Kinda like that spanking as a child you got when your mom and pop knew something happened but wasn’t sure so it was just to make sure!
Ford Bronco ¡ Bronco Will Not Get A Disconnecting Sway Bar ! 60760AC9-A855-4140-AC49-43C17F13403F
OX1
jackson nj
No, it was funny as heck. :clap:
I've wondered if Ford was going to come up with some kind of killer
traction control to help overcome not having a wheel on the ground. In theory, you have all the weight
on that one tire, it should have pretty good traction IF you can turn that diff into a spool for a split second.
Although I have ARB-like diff',s stock in my mogs, they are not ideal for generally tooling around the trails locked up.
Would be cool if electronically, the diff could lock up when needed, and I don't mean braking the other wheel,
as that would mean it gets braked until it gets back to a surface and I wouldn't want it locked up for even a
split second after it gets back to the ground.....
Amos Moses
Trae
North Florida
Ford trucks
Being able to get up to 37" tires off the showroom floor is awesome but do you know the maximum size the ifs was designed to handle. I also would like to know if y'all will be offering a factory M/T tire (Mud Terrain).
jjmtuttle
Jeffrey
Usa
No idea on the aftermarket parts or fits... We got a New Goodyear M/T Also have New BFG A/T that will both will be New to us.. we only had Hankook and Bridgestone before on the Ranger.. Bronco will have 5 matching tires so can be put into rotation
Status
