- Dennis
- Jul 13, 2020
- 2
- 264
- 487
- Hurricane Alley
- 16 F150 ,89 325i and 72 Dodge Charger SE
- Badlands
How are you straining a clutch leaving it in gear while rolling. That makes 0.0 sense. Unless you're clutch is worn and slipping the engine and trans are connected with the clutch engaged. Have a BMW with 100k on a clutch never downshift on the highway when I need to speed up or go up hill.The question you should ask is not whether the engine will be damaged by boost or RPM pulling hills. The question is wear on your clutch. If you are going up hill in 6th gear you should downshift to 5th or 4th or maybe lower depending on grade and vehicle speed. If you attempt to accelerate in overdrive (6th/ even 5th in some instances)up hill you are putting more stress on the clutch than in a lower gear and can cause early wear.
On a 4cyl rpm is your friend, like already stated by Kodiakisland.
